Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Hello,
I consistently get the following error message when i try
to use the internal windows compression utility to
package files
windows compression (zipped) file error
cannot create output file
it doesnt matter what type of files i am zipping up, same
problem
it will happen approximately 70% of the time
i was told it could be a problem writing to the hard
disk, so i replaced the hard disk and a fresh install of
windows, same problem
ive tried replacing my memory modules, same problem
i have onboard LAN and VIDEO (not that it should make a
difference)
the only thing i havent done is replaced the board
any suggestions?
thanks
Hello,
package files
problem
difference)
any suggestions?
thanks
