how much power do i need?
i've been looking into making my own computer and im stuck on what kinda of psu to buy....
here's my setup
msi 6380LE KT266 DDR m/b
1.2 athlon t-bird 266fsb
lian li pc-60 case
256 mb pc2100 DDR ram
52x cd-rom
msi 64mb geforce 2 pro
floppy
possibly a burner
so my question is, is 300 watts enough or should i go higher?
6 answers Last reply
More about power need
  1. if you go higher it'll help ensure that you won't have to upgrade it with your computer, but more power=more heat, and more heat=more fans, and more fans=more noise...
  2. Go to www.amd.com and drill-down into the Athlon Processor link and look at the recommendations. AMD provides a rather larger list of recommended & tested P/S, M/B....etc. You will be able to make a more intelligent choice of your own.
    JC-------<*){{{>{~~~~~
    Fisher of men
  3. 300 watts should be plenty for the system you describe, but if you want to go any higher with your processor, any more drives, or a newer video card you would want to look into a power supply upgrade.
    But power supply's are easy to put in and out, so it's not a big hassle if you have to do it later.
    Keyboard not found press F5 to continue.
  4. I suggest a minimum of 350 watts. More impprtantly you need to have at least 180 watts acropss the +3.3 and +5 volt lines collectively. Inadequate power is the most overlooked part when it comes to instability, Get more than enough and eliminate it entirely.
    Video editing?? Ha, I don't even own a camera!
  5. Get something around 400 watts. Everyboady keeps upgrading their power supplies every 6 months, by the end of the year 400 will proabably be what you need to run AMD's fastest processor anyway!
    I'm so tired of cookies I'd settle for spam!
Motherboards DDR MSI-Microstar
