G
Guest
Guest
I have Biostar M7VKA motherboard and AMD Duron 700mhz CPU and ATI graphics card. My problem is that when I select SHUT DOWN in windows my computer gets as far as a black screen with flashing cursor and then locks up. The only way to turn it off is at the wall socket. This happened once before and I cured it by re-formatting and reloading everything. Is there an easier/quicker fix? Has anyone else come across this problem?
