G
Guest
Guest
Here's what happened...
During a storm my computer stopped working (I was golfing in another city so I don't know what exactly happened prior to it shutting down). When I opened the case to look inside, the fan had broken off the socket (one of the plastic clips broke). It was my first suspicion that the chip was fried although I could tell no visible difference. I took the computer to a local guy and he came to the same conclusion and added that the mobo was probably fried also. Before I buy new stuff, I wanted some other opinions.
Here's what happens when I attach the fan and turn the computer on: the lights come on and it makes it's initial noises but I can see nothing on the screen. I don't even think that it posts (it doesn't sound like it does). The monitor sits in sleep mode and when I unplug the monitor cable, the monitor "wakes up" and shows a warning for me to check the cable.
Specs:
1.2 ghz Athlon T-Bird
Asus A7M266
512 MB Micron PC2100 DDR
ATI Radeon 64 MB DDR
What's the deal?
<font color=green>Modern art, is it art? Nope, I realized, some things are just stupid.</font color=green>
Specs:
Asus A7M266
What's the deal?
