Tom's Hardware > Forum > Systems > HP > NC8000 Power conservation settings question
Forum Systems : HP - NC8000 Power conservation settings question
Archived from groups: comp.sys.hp.hardware (More info?)
Hi all, when you plug the power adapter into the laptop, the screen gets
brighter, when you remove it dims. This is part of the power conservation
settings. On the older M700 laptops, you were able to switch this off using
the drivers downloaded from Compaq/HP. The drivers from Compaq/HP for the
NC8000 dont seem to have this feature.
I was wondering if anyone knew of a way to stop this? I'd really like to
have the same brightness settings all the time, no matter whether I have the
power adapter plugged in or not.
Cheers Dre
Sponsored Links
> Cheers Dre
Perhaps it is now a *BIOS* setting. At least it is for my HP OmniBook
vt6200:
Power -> Backlight control
This has two settings:
- "Auto Restore", for which the "Item Specific Help" says "Backlight
brightness automatically remembered.".
- "Auto Dim", for which it says "Maximizes battery life.".
I hope this helps.
Reply to Anonymous
"Frank Slootweg" <this@ddress.is.invalid> wrote in message
news:431d8d1d$0$64045$dbd41001@news.wanadoo.nl...
conservation
using
the
to
the
> > Cheers Dre
> vt6200:
> I hope this helps.
Thanks for the info, but no, this isn't an option in the bios :(
Cheers Dre
Reply to dre
There are 1016 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
