G
Guest
Guest
AMD 1.4 GHz
DFI AK 76SN mobo
Geforce 2 GTS/Pro 64MB DDR
Sb Live! 5.1
linksys LNE 100
Maxtor 40 GB 7200rpm hdd
The problem is that it doesn't perform well. It hangs so often. I use Win 2000 OS. So I check in the conflict list and find that the AGP card, the network card and the soundcard is sharing same IRQ. I think this might be the problem why my rig is not performing well. But I don't know how to get it right. And in the AGP card, the video capture (universal) drive is not working. The eror code 10 is showing when i try to install that device.
Plz give me some help..
Thx
DFI AK 76SN mobo
Sb Live! 5.1
linksys LNE 100
Thx
