Basically I have just built a pc with the following spec:
Intel Core i5 2500k 3.30GHz @ 4.40GHZ overclocked
Gigabyte Z68AP-D3 Motherboard
Kingston HyperX Genesis Grey 8GB Ram
ATI Radeon HD 6870 1024mb Graphics Card
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache 7200rpm HDD
OCZ 750w PSU
The problem is, it seems to run any other game I have tried appart from wow fine. However, when I come to run wow, even in the starting areas it runs fine for about 2 mins then drops dramatically to about 2fps and I cant even move! My CPU monitor says it is running at an average of 42 C over the 4 cores and at about 2-3% useage. The GPU monitor says the graphics card is running at 57 C, fan speed about 47% and usage is sky high at 99%!
I don't know why this is happening, I do have the settings on wow maxed out but it shouldn't be a problem for this system?
Another problem is if I try run it with my monitor as the display unit, by the time I get to the character select screen, my screen just goes 1 block colour and freezes, having to reboot the pc! If I run it through a HDMI cable on my TV it will run and load fine, but like I say, the game runs so slow its unplayable and freezes at any oppertunity it gets!
Can anyone help me with this problem please? I've included a link to a screenshot of me running wow below:
Thank you in advance!
http://imageshack.us/f/820/pcproblem.png/
OCZ 750w PSU
