I use a 22" Acer x223w LCD monitor which, according to the Acer site is HDCP compatible. I recently bought an HDMI - DVI conversion cable so that I could play my PS3 on the monitor since I only have older CRT TVs (Big screen, low definition)
From everything I have read I should be able to plug the cord in to my PS3/Monitor, hold the power button for 6 seconds in order to reset the PS3's display options so that I can select HDMI output and start playing.
However, when I connect the cord the monitor registers the connections and goes to sleep when the PS3 is off (As it should) but when I turn on the PS3, the monitor's message changes to "cable not connected" and stays that way.
I have updated my monitor's drivers, and attempted to set the PS3's output to HDMI though my TV (Although that doesn't work since I only have CRT TVs) and nothing seems to work.
Help would be greatly appreciated, and if there is any other forum where this would be better suited to go then please point me in that direction =) Thanks.
Edit: I have made some progress, although I'm not sure what I did other than commit my DVI port to my PS3 and switch back to using the VGA port for my PC (So that I don't have to change plugs and can just flip a switch) and now the screen is black with an "Input not supported" message. Supposedly this is something that happens with my monitor model. The only guides that I can find are from several years ago so the PS3 menus are a little different. (A problem since I have to do it without seeing what I'm pressing)
