I am planning on building the following system and was looking for any suggestions or compatibility issues that anyone has with the components/system below. I have a limited budget but want the best system for the lowest cost. I have an old system I will be raiding for some components. This will be the first system I have put together from scratch and I haven't ever overclocked. I will be running Win98 SE will be using my system for the Internet, AutoCAD, ProE, and gaming.
New Components:
MOB Bundle from Mwave.com ($269):
* Epox EP-8K7A (AMD761+VIA 686B Chipset)
* AMD Athlon 1.4GHz (266 FSB)
* Heatsink/Cooling Fan
* Assy and testing
256MB DDR PC2100 (Crucial: $39.59)
* CL=2.5, Unbuffered, ECC, 2.5V, 32Megx72
Radeon LE DDR 32MB AGP OEM (Newegg.com: $71)
* Plan to overclock and tweak registry
IBM Deskstar 60GXP 40GB (Mwave.com: $133)
Antec SX635 (EMS Computing: $80)
* 350W PS
Pioneer DVD-116 16X (Newegg.com: $55)
Generic 1.44MB Floppy Drive ($8)
Microsoft IntellMouse PS2 OEM ($9)
Generic Realtek NIC to link to old system ($5)
Total New: $669.59
Existing Components to be used:
Sound Card: use onboard or existing AoOpen PCI Audio AW744
Monitor: Princeton Graphics 17EO (17" FST/0.26mm/1280x1024NI/100Hz)
Modem: Comet Deluxe 56kbps PCI Voice/data/fax
CD-RW: Acer CRW4432A (4x4x32)
Speakers: Altec Lansing ACS45 Spkr/Subwfr
Keyboard: Microsoft Natural Keyboard
OS: Win98SE
Sponsored Links
If your budget is tight you might want to look at the ECS K7S5A SIS-735. I'm waiting for mine from newegg.com (65.00 + 5.00 SHIPPING u.s.) All the reviwers are saying good things about this board (the guy at newegg told me they sold out there stock of 200 mobo in less then 2 hours) Also you didn't mention the type of hsf. I would go with something good like a thermalright or swiftech. Also if its any help that memory can be had for $35.95 @ crucial.com + free shipping.
Reply to Anonymous
Since you mentioned low cost as being important to you, and if you don't plan on overclocing, then the ECS board with the SIS735 chipset would be perfect for you.
See a real naked pic of Britney Spears <A HREF="http://www.geocities.com/stick_e_mouse" target="_new">here</A>!!!
Reply to Stick_e_Mouse
yeah...the sis 735 mobo by ecs would be a good thing for you. it will offer speed, reliability, and since you dont want to overclock, it will fit you like a glove.
good luck..oh yeah, when you order yours, order me one too...J/K!!!!!!!!!!!
-DAvid
-Vacuums suck...really...-
Reply to HonestJhon
Forget that. I run the 8k7a+ with a 1.4 Tbird - stable, fast, cheap, easy to OC.
Looks like a good system - but RAM is so cheap, just get 512 now. 256 is for chumps. :wink:
<b>ßunn¥§troker 0wn§ j00!</b>
Reply to BunnyStroker
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Help on new AMD system
There are 978 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
