Start Menu problems (among other things)
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
OK, this problem is driving me up the wall.
I can't use my start->programs menu. I can open it, but I
can't select anything in it, not even with the keyboard.
The blue highlighting bar never appears. But the system
DOES NOT lock up! I can easily close the menu with the
mouse or keyboard, I just can't use it. And it's just the
programs menu, the rest of the start menu works fine.
Another thing I have noticed that seems to stem from the
same problem (at least they always happen in tandum) is
that my keyboard stops working in certain programs. I've
noticed this most often in ZSNES (the win32 verson). The
mouse works fine but the program won't respond to keyboard
input. However, the windows key and other shortcuts
(alt-f4, ctrl-alt-del, etc.) still work normally. I
thought it might just be the program, but the fact that it
only happens when this start menu thing breaks leads me to
think that the problems stem from the same source.
This problem used to go away after a reboot, but the last
three or four times i've rebooted it's been there from the
beginning. I should note that it doesn't happen exactly at
startup, usually about 30 sec. after I log on.
If anyone has any clue as to what's going on, I would be
very apreciative. I really don't want to have to reinstall
the OS. It's such a pain.
Systems Specs:
OS: Windows XP Home (Without SP2, uninstalled it to see if
it fixed the problem, it didn't.)
CPU: 3 GHz Pentium 4
RAM: 1 Gb PC3200 DDR
Soundcard: Soundblaster Audigy 2
Video Card: ATI Radeon 9800 Pro
1 answer Last reply
More about start menu problems among things
  1. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    I would run error checking. Need help? Open help and
    support and search for "error checking"
    Also you can get more
    inforation by opening up event viewer.
    Need help? Open up help and support and search for "event
    viewer"
    Look for red colored events that in application and
    system that relate to time of your error and open, that
    will give you a module(program) maybe a .dll also. Use
    Search companion to look up that program name to isolate
    what is giving you a problem.Then select microsoft
    link. Repy yes. That will open up help and support(if you
    have an internet connection} If need to copy and paste
    here at this newsgroup.
    >-----Original Message-----
    I
    the
    keyboard
    it
    to
    the
    at
    reinstall
    >Systems Specs:
    if
Start Menu Keyboards Windows XP
