Tom's Hardware > Forum > Systems > HP > HP compaq nx6110 keypad problem
Forum Systems : HP - HP compaq nx6110 keypad problem
Archived from groups: comp.sys.hp.hardware (More info?)
Hello,
I have to write German letter frequently. Does anybody know how I can write
the German "Umlaute" on the notebook?
On my PC I use for example ALT+129
Thank you very much, Jürgen
Sponsored Links
"Jurgen Bauer" <jbauer@jbauer.fsnet.co.uk> wrote in message
news:dgnbml$im3$1@newsg4.svr.pol.co.uk...
> Hello,
On my Omnibook I can use the Fn and alt keys together with the embedded numeric
keypad - ü is Fn+Alt+j+k+9.
Regards,
Bob Headrick
Reply to Anonymous
[Subject: changed.]
> > Hello,
> > can write the German "Umlaute" on the notebook?
> embedded numeric keypad - ü is Fn+Alt+j+k+9.
[This is a recording:]
Dear Outlook Express user,
Your posting uses local language characters like u+umlaut, but
it does not contain the required MIME headers which specify the correct
character set (probably ISO-8859/1). You can fix this as follows:
Tools -> Options... -> Send -> News Sending Format -> Plain Text
Settings... You probably have "Message format" set to "Uuencode" (which
is some stupid OE default). If so, set it to "MIME", set "Encode text
using:" to "None" and do *not* set (i.e. no tic-mark) "Allow 8-bit
characters in headers".
You may want to set the "Mail Sending Format" the same.
If you reply after fixing this, then please add some local language
characters, so that I/we can see/check if everything is OK.
Best regards,
Frank Slootweg
[End of recording. 21SEP2005.]
Reply to Anonymous
There are 1287 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
