Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > high speed wireless in the north
Forum Wireless Networking : Wireless General Discussions - high speed wireless in the north
Archived from groups: alt.internet.wireless (More info?)
i need to know if anyone can help me run high speed internet through the
forest or northern canada. there is high speed internet adsl or cable
withing 2miles of my house but to my house i can only have dial up. is there
a wireless repeater or long distance transmitter i can use. i want to send a
signal from my friends house to mine, it is sparsley treed but it is not
open. can someone give me some ideas. i have read linksys site and they say
700 ft open terrain or 500ft in an office building. i cannot carry on with
dial up anymore and the isps are never going to come to my house. thanks in
advance.
Sponsored Links
> advance.
If you have clear line of sight (a "few" trees may kill the deal) then
wireless is the quick/easy/cheap way to go. Any way you can you get
above the trees? A couple of outdoor bridges with panel antennas would
make the distance you mention. Such as:
http://shorterlink.com/?RM2KRQ
The prices listed are retail, they can be found cheaper.
Reply to Roger
You may want to find wireless equipment not made for the US/Canada
market. I don't think that some countries have to abide by the same
power restrictions that we have here in the USA.
Just a thought.
Also there are some good directional antennas that can be bought and/or
made.
Height is your biggest friend. Every time you double your height, you
double signal strength.
Also you may be able to use an old direct tv or dish network dish and
use that. it's very directional with lots of gain.
Use large low loss coax for your connection between the antenna and your
access point and/or your computer.
Dave
Rôgêr wrote:
>> the forest or northern canada. there is high speed internet adsl or
>> cable withing 2miles of my house but to my house i can only have dial
>> up. is there a wireless repeater or long distance transmitter i can
>> use. i want to send a signal from my friends house to mine, it is
>> sparsley treed but it is not open. can someone give me some ideas. i
>> have read linksys site and they say 700 ft open terrain or 500ft in an
>> office building. i cannot carry on with dial up anymore and the isps
>> are never going to come to my house. thanks in advance.
Reply to Anonymous
- 0 +
> Just a thought.
Yes, unbelieveably, some countries are more restrictive than the USA or
Canada. Unless you meant *more* powerful than what is allowed? You'd
advise someone to break the national communications laws and risk
extremely high fines?
> made.
Height is good, but "double your height, you double signal strength" is
pure BS.
You'd have to know how to adapt one, it's not simply a matter of
slapping it up on the side of the house.
What kind do you recommend, just any large coax? I'd go with LMR400 for
most purposes, but crimping connectors is problematic for most people
who don't want to invest in more tools, connectors, etc. If the OP
sticks to outside bridges, no coax (and the associated signal loss) is
needed.
> Dave
>>> an office building. i cannot carry on with dial up anymore and the
>>> isps are never going to come to my house. thanks in advance.
Reply to Roger
>> Just a thought.
There are countries that are less restrictive, also.
And Yes, i'm suggesting that somebody can decide for them selves what
equipment they want to use.
In the great white north, does rf get transmitted if no one else can
receive it?
>> and/or made.
> pure BS.
If you look at the equations it is true. It also depends if the
antenna's have line of sight to begin with.
If you surf the internet there is information about how to do this.
>> your access point and/or your computer.
> needed.
LMR400 seems like it might be a very good choice.
There is also merit to outside bridges.
At least he is getting lots of suggestions.
>> Dave
>>>> dial up. is there a wireless repeater or long distance transmitter i
>>>> can use. i want to send a signal from my friends house to mine, it
>>>> is sparsley treed but it is not open. can someone give me some
>>>> ideas. i have read linksys site and they say 700 ft open terrain or
>>>> 500ft in an office building. i cannot carry on with dial up anymore
>>>> and the isps are never going to come to my house. thanks in advance.
>>> then wireless is the quick/easy/cheap way to go. Any way you can you
>>> get above the trees? A couple of outdoor bridges with panel antennas
>>> would make the distance you mention. Such as:
Reply to Anonymous
>advance.
2 miles is possible with good antennas. Do you have line of sight
between endpoints? If no line of sight, forget it. You can go
through a few branches here and there, but anything resembling a
forest is impossible. You will probably need two 24dBi dish antennas
and if you plan to run more than one computah, a pair of radios
capable of transparent bridging (DWL-900AP+, WAP54G, etc).
If you don't have line of sight, it might be possible to install a
midpoint wireless repeater. However, your thruput will be cut in half
and you'll need two additional antennas (can't be done at 2 miles with
an omni).
If you insist on going through the forest, 900MHz goes through much
easier than 2.4Ghz. Finding 900MHz bridges is rough. The access
point and client variety of 900MHz radios (WaveRider, Motorola
Canopy), will not talk between clients, so that's out. I've used a
few point to point 900MHz radios (FreeWave) but not current bridges.
See:
http://www.avalanwireless.com
for a possible pair of radios that might work through the trees.
935kbits/sec thruput. $1000 per pair with antennas. Ouch. If you go
this route, let me know as I also live in a (dense) forest and have
similar problems.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:7noos0dcuk2nb5kbo6t0mea43evin9iqen@4ax.com...
through the
cable
is there
to send a
is not
they say
on with
thanks in
> >advance.
antennas
half
with
> an omni).
> See:
go
> similar problems.
Have you considered a satellite? Might be your best option
Reply to Anonymous
On Fri, 24 Dec 2004 14:16:22 -0600, "Airhead"
<campbell@alliancecable.net> wrote:
(chop...)
For Canada:
http://hns.getdway.com/var_canada.html
http://www.xplornet.com
Approx $80/month plus hardware and install.
$75 Canada license and $75 "Access Fee".
http://www.lincsat.com/e/1000/1501e.asp
500Kbits/sec (max) down. 50Kbits/sec (max) up.
Slows down after about 170Mbytes downloaded to prevent hogging.
600-1000msec latency.
Needs clear view of the sky to the south.
Also:
http://www.starband.com/findadealer/index.asp
$70/month plus $400-$800 for hardware.
http://www.starband.com/residential/index.asp
I think there's one other consumer grade satellite internet provider
for Canada, but can't seem to find the name.
This is better than a one time $1000 equipment charge?
Reply to Anonymous
On Fri, 24 Dec 2004 19:20:43 GMT, in alt.internet.wireless , tes@test.com
Actually you're saying they can decide for themselves if the law of the
land applies to them. This generally isn't true!
>receive it?
And if a plane crashes, or a nearby inuit with a pacemaker keels over, then
what?
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt>
Reply to Anonymous
In article <8LKdnZ6f2NbcxlHcRVn-1A@pghconnect.com>,
> pure BS.
If you're a broadcaster or 2-way operator, with an "omni" antenna, added
height increases your coverage area equivalent to the effect of a power
increase, so in that instance it's not BS. But for the "point to point"
application in this thread, you're right. Height only matters if
adjusting it helps make a clear path between the two antenna sites.
Chuck Reti
Detroit MI
Reply to Anonymous
thanks for all the advice, i have contacted all the sattelite providers and
i am waiting for reply. the line of sight is not an option for me from what
i have read on the equipment dealers sites. thanks again.
"up north" <nomail@north.net> wrote in message
news:0fOyd.550818$Pl.423987@pd7tw1no...
>there a wireless repeater or long distance transmitter i can use. i want to
>send a signal from my friends house to mine, it is sparsley treed but it is
>not open. can someone give me some ideas. i have read linksys site and they
>say 700 ft open terrain or 500ft in an office building. i cannot carry on
>with dial up anymore and the isps are never going to come to my house.
>thanks in advance.
Reply to Anonymous
There are 1102 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
