Archived from groups: alt.internet.wireless (More info?)
I got my netgear wirless setup with XP and running Sygate Firewall Pro,
to enable me to view websites properly I have to disable sygate,
I cant access my hotmail and some webpages wont show up ie. ebay
and others if sygate is enabled,
I had the same setup running ok before I done a new install of XP a while
back,
"Cookie" <test@test.com> wrote in message
news:41cc5895$0$19162$cc9e4d1f@news-text.dial.pipex.com...
> back,
> I've tried varous setting in sygate but no luck
> Any ideas?
> Thx in advance
Also I cant send my pop3 (pipex) mail using outlook when sygate is enabled,
I can receive mail ok.. mm strange
news:41cc6dc5$0$16589$cc9e4d1f@news-text.dial.pipex.com...
Pro,
a while
> > back,
> > Any ideas?
Maka sure you have the XP firewall turned off.
Check your security level in Internet Explorer....
Tools/options/security
> > Thx in advance
enabled,
sounds like firewall overkill. your router has a built in router and that's
generally enough. add in windows firewall and sygate just adds to the
clutter.
"Airhead" <campbell@alliancecable.net> wrote in message
news:41cc736d$0$22514$2c56edd9@news.cablerocket.com...
> Pro,
> a while
>> > back,
>> > Any ideas?
>> > Thx in advance
> enabled,
Thanks for the replys...
XP was turned off, I changed security level to default, this was
on custom, I can't recall ever changing these settings before.
I still cant access my hotmail or ebay account with sygate enabled,
but pop 3 pipex seems to be working ok.. getting there :-)
>that's
>clutter.
Sometimes when firewall is enabled I get intrusion's and warning's,
router firewall only blocks incoming traffic, sygate is good for spyware
etc..
I'd like to keep running it :-( I had them running together before,
I have anti spyware installed aswell.
