Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Can You Help? Routing Through a Hub
Forum Wireless Networking : Wireless General Discussions - Can You Help? Routing Through a Hub
Archived from groups: alt.internet.wireless (More info?)
I have a Compaq 2404 WBR 802.11b wireless router.
Current configuration
I have a cable modem and a maximum of 2 dhcp client addressess allowed from
my cable ISP. I have 4 computers, only 1 of which has a wireless adaptor.
I don't have enough addresses.
Currently, 2 computers are being passed dhcp addresses from the ISP. The
wireless router is not yet configured but when it is, it will also need a
dhcp address. However, if I can configure it correctly, it will be the only
device receiving a dhcp client address.
The cable modem is attached to a hub. The hub is attached to the wbr at one
of the 3 non-WAN ports on the wbr (I assume the wbr is hardwired such that
the WAN port needs to separately connected to the cable modem, but I haven't
done that yet
-- due to distance from the cable modem I was hoping to be able to route
without using that WAN port).
Problem
When I turn on dhcp at the wbr it never routes to/from any of the wired
computers out to the Internet. However, it does -- in testing -- route a
wireless computer to the Internet.
What I want
I want to receive DHCP addresses on my wired network, from the wbr. I
assume I'll have to give the wbr 1 address from the ISP. I'd like the
remainder of the addresses -- for 4 computers -- to come from the wbr. How
do I get the wbr to route wired computers to the Internet?
Any suggestions to accomplish my goal?
Sponsored Links
On Fri, 24 Dec 2004 14:53:15 -0600, in alt.internet.wireless , "Rick"
why not just connect the above router directly to your cable modem, turn on
DHCP, configure all your clients to get addresses from it. You can
generally run a long length of CAT5 from the modem to the router without
any problems.
Yes.
This just won't work. The router expects the modem to be on the WAN port,
and will try to get a DHCP addy from that port.
By using the router properly !! Its a router, its designed to link two
networks (the internet and your LAN), so use it to do that !!
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt>
Reply to Anonymous
"Rick" <badnew@goodnews.com> wrote in
news:0u%yd.46951$mf7.43310@fe05.lga:
> from my cable ISP. I have 4 computers, only 1 of which has a wireless
> adaptor. I don't have enough addresses.
> The wireless router is not yet configured but when it is, it will also
> need a dhcp address. However, if I can configure it correctly, it
> will be the only device receiving a dhcp client address.
> at one of the 3 non-WAN ports on the wbr (I assume the wbr is
> hardwired such that the WAN port needs to separately connected to the
> cable modem, but I haven't done that yet
> route
> Problem
> wired computers out to the Internet. However, it does -- in testing
> -- route a wireless computer to the Internet.
> What I want
> How do I get the wbr to route wired computers to the Internet?
You flip it. The modem connects to the WAN port on the router. You can
plug the hub into one of the LAN ports on the router to extend the
network. You can also connect one hub to another hub to extend the
network and so on and so on. The router can control over 200 computers
issuing a DHCP IP to each computer. The router also has a built in smart
switch. The router is the gateway device for the LAN and WAN. It is not
the hub.
http://tinyurl.com/6agku
http://tinyurl.com/leps
Duane :)
Reply to Anonymous
The cable modem is in the basement. If I connect the router to the WAN port
I have to have the router in the basement. I have computers on the 2nd
floor of my house that get poor wireless reception if the router is down in
the basement, so I was trying to avoid that.
I'll find another solution.
Thanks for your insight.
"Mark McIntyre" <markmcintyre@spamcop.net> wrote in message
news:9r6ps0921mu6bbdkccd171mfeacsr0t31t@4ax.com...
on
> any problems.
only
> Yes.
one
How
> Mark McIntyre
Reply to Rick
No, you don't. Any of your Ethernet cables can be 100 meters long.
Reply to Anonymous
On Fri, 24 Dec 2004 22:37:24 -0600, in alt.internet.wireless , "Rick"
No, just run a long ethernet cable from the modem to the router WAN port -
you already have one, since you've somehow attached the modem to one of hte
router LAN ports....
For what its worth, my wireless router is currently around 100ft from my
modem, as the cable runs.
Mark McIntyre
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply to Anonymous
Actually, yes, I do. I don't have cable run except for the one cable. It's
not an issue of acceptable cable length, it's an issue of where I can run
cable and distance from router. I would need 2 cables from the basement to
the first floor, and I only have 1, and no plans to run another.
"Neill Massello" <neillmassello@earthlink.net> wrote in message
news:1gpcd2y.1j0ol4czhqcjwN%neillmassello@earthlink.net...
port
Reply to Rick
It's not a question of cable length, but thanks for the try.
As it stands, I'll put the router in the basement and accept poor wireless
reception.
news:gqsrs0p3bq52knkoqojmhumkj3d54g5met@4ax.com...
port
hte
> Mark McIntyre
News==----
Newsgroups
Reply to Rick
Final solution:
I'll use the one long cable from basement to 1st floor to connect the modem
to the router. Then I'll put a wireless card on the basement computer as
well as the other computers. The solution is really to make nearly all the
computers wireless. If I kept the basement computer wired I would have had
to either run 2 cables -- 1 up to router and 1 down to basement computer --
or leave the router in the basement with poor wireless reception on the 2nd
floor.
"Rick" <badnew@goodnews.com> wrote in message
news:0u%yd.46951$mf7.43310@fe05.lga...
from
only
one
haven't
> done that yet
> Problem
> What I want
How
Reply to Rick
If you need to connect devices in the basement, get a wired router (less
than $40 these days) for the basement and connect the long Ethernet
cable to one of its LAN ports. Upstairs, connect the other end of that
cable to one of your wireless router's LAN ports. Disable NAT and DHCP
functions on the upstairs router so that it functions as an access
point.
Reply to Anonymous
On Sun, 26 Dec 2004 01:16:00 -0600, in alt.internet.wireless , "Rick"
I don't understand - you have a cable running from the basement to the 2nd
floor already no?
Mark McIntyre
Reply to Anonymous
On Sun, 26 Dec 2004 01:22:09 -0600, in alt.internet.wireless , "Rick"
>Final solution:
>floor.
Or as someone said, buy a wired router, put that in the basement attached
to your modem and basement computer (modem into WAN port, computer into LAN
port) and run your long cable up to your wireless router - attach to a LAN
port on it. Disable DHCP on the wireless router and all will work fine.
Mark McIntyre
Reply to Anonymous
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
