Archived from groups: alt.internet.wireless (More info?)
I have a Linksys wireless adapter (WMP11) installed in a new Dell Dimension
3000 running Windows XP SP2.
I have my preferred network configured to auto-connect so that when I start
my pc I'm automatically online.
The trouble is, most of the time the adapter does not connect automatically
and I have to do it manually. I was wondering if anyone had any ideas as to
why this option behaves so unreliably.
> Dimension 3000 running Windows XP SP2.
> start my pc I'm automatically online.
> automatically and I have to do it manually. I was wondering if
> anyone had any ideas as to why this option behaves so unreliably.
> Rich
Try these: set infrastructure-only mode in adapter; set router/adapter
to open key; broadcast SSID; remove all networks except yours from
preferred networks; uncheck the box in the advanced properties
"automatically connect to non-preferred networks"; change the channel;
change the SSID. Also, use either WZC or the Linksys config utility but
not both running simultaneously. Some have reported that running the
wireless network setup utility twice or more will cure this problem.
Also, what signal level are you getting at the PC?
Q,
Thanks for the feedback, I will experiment with your suggestions. My signal
strength always shows "Very Good".
Rich
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news5Gdndh2PKV58FDcRVn-qA@comcast.com...
>> Rich
> Try these: set infrastructure-only mode in adapter; set router/adapter to
> open key; broadcast SSID; remove all networks except yours from preferred
> networks; uncheck the box in the advanced properties "automatically
> connect to non-preferred networks"; change the channel; change the SSID.
> Also, use either WZC or the Linksys config utility but not both running
> simultaneously. Some have reported that running the wireless network
> Q
Q,
I'd also like to note that this pc has both an integrated nic card and a
wireless adapter. I noticed a query in Linsys' kb regarding this and
Linksys said the nic card should be disabled.
I was thinking about trying this one also, although the nic card is
unplugged and I don't see why that should be a problem, any thoughts?
Rich
>> Rich
> Q
> Q,
> and a wireless adapter. I noticed a query in Linsys' kb regarding
> this and Linksys said the nic card should be disabled.
> Rich
>>> I start my pc I'm automatically online.
>>> Rich
>> router/adapter to open key; broadcast SSID; remove all networks
>> except yours from preferred networks; uncheck the box in the
>> advanced properties "automatically connect to non-preferred
>> networks"; change the channel; change the SSID. Also, use either WZC
>> or the Linksys config utility but not both running simultaneously.
>> Some have reported that running the wireless network setup utility
>> twice or more will cure this problem. Also, what signal level are you
>> getting at the PC?
>> Q
Disable the ethernet simply to prevent annoyance from the "cable
disconnected" error. It's pretty much standard practice in XP with
wireless connections.
Q,
Not sure if you're still following this thread, but I found that when I
enabled broadcast ssid, my pc started autoconnecting as it should.
Thanks for all your input.
Rich
>> Rich
> Q
