i need advice installing my motherboard in the case,its a slide out tray. ok i have parts that came with the case the screws, they are gold octagon shaped and at the top of it there is another screw hole ,.do you screw that gold one to the tray and then lay the motherboard over them and then screw the motherboard to the holes that are lined up with the gold screws. there were no washers that came with it do you need to use any? i have an asus a7a266 motherboard.thanks
Thats it exactly. A good tip is not to over-tighten when installing a MB. Firm but fair. I've had probs getting this MB up and running under WindowsME with instability and poor performance in 3D games. The solution I found was not to install any ALI AGP driver. You might want to test it without before comparing to the performance after this driver is in place.
cool,thanks for the advice i will try it.i will be using win98se.. this is my first time building a pc so i really hope all goes well with it.. thanks again..
JP........
