Hello,
I have bought Xbox 360 Slim 4Gb 4 days ago. And yesterday i had a problem with video. I've used HDMI to DVI cable for 1080p resolution on my monitor, which worked fine. I have played standard game - Phelix HD or something called like this. Then i removed the cable from my monitor, and plugged my pc cable there. After 1 hour, Xbox turned off, then i put back cable for Xbox into monitor, and started It. And at startup there were flashing yellow dots all over the screen, nothing helped till now.
Only 720p resolution works fine without flashing dots. 420p has a lot of dots, and 1080p smaller.
I don't know how that would happen... And how to fix it...
Take my xbox back to store, to repair it. Or try another cable ?
