Hi, I previously posted this problem on the "others" board and I got many replies which I am thankful for but they did not seem to work. Umm, first of all my problem is that my computer at abrupt times, looks as if its gonna reset but it just quite doesn't, not sending any signals to the monitor. I can't reset it both using ctrl+alt+del and the reset button and also I can't turn it off using the conventional power button. I usually switch off the power supply but if I don't switch it off in time and turn it back on, the computer still is unable to boot up, showing a black screen. When this happens I have to disconnect every piece of hardware from the motherboard and stick it back in, in order for it to work again. My motherboard is a k7 pro msi. I dunno what's wrong with it.
Everytime it does this, there are 4 led's which usually are green, turn red. All that seems to run is the fans.
I was told to format my hard drive, which I did but that didn't help at all. It did happen when I was in my bios, which is really peculiar.
If anyone has an answer, please help me!! PLEASE!! Thank You! If you need more information about my computer to solve this problem, please ask.
PS. Sorry for the bad grammar.
