i am getting problem with Ms word. when ever i tried to work with word it hangs the system. in taskmanager it creates the winword.exe. when i delete this instance it closes the word also. can any one please give me solution for this problem.
Sponsored Links
It's a template problem.
C:\Documents and Settings\[your username]\Application Data\Microsoft\Templates
Close Word. Go to the above location, delete Normal.dot.
Open Word, adjust Word to how you want it - ex. Times New Roman as default font, show toolbars on 2 rows, etc. just customize how you want it.
File - Save As - navigate to the above location, document type should be Template. Save the file as "normal.dot"
The Normal.dot is the template that everytime you open Word it references that file.. it holds your macros, customize settings, etc. etc.
Well, it got corrupt and I haven't found a way to recover that file yet, except to make backups of it periodically when you start doing extensive customization within Word.
No other office program uses this kind of template. Excel, for example, has a static template it uses and you won't find this problem there. It's strictly within Word.
Let me know if that fixed it...
Reply to Riser
Tom's Hardware > Forum > Applications > Other Software > Ms word problem
There are 1024 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
