G
Guest
Guest
I just upgraded my old P133 (which I intend to use as a linux firewall/router to my new box) with a bit more memory. However, in order to get at the memory, I had to unplug some of the IDE cables since the memory sockets are located in an ungodly location directly underneath the power supply and right beside the IDE connectors.
Anyway, while I was unplugging that cable, I believe I accidently unplugged a 2 wire (red & black) connector that leads directly to my power supply. After re-attaching all the other wires (at that time, thinking the connector was an extra one, which my power supply has a plenty), my computer will not turn on.
The motherboard is an A-OPEN socket 7, circa 1996 I believe.
If anyone has any idea why it's not booting (and I will kick the person who suggests I didn't plug it into the wall ), I would appreciate it greatly.
(edit) Since it would probably help, I can see 2 possible sets of pins I could attach it to. Assume I have the motherboard turned so that the long edge with the CPU is towards me, and, the PCI slots are on the long side away from me.
6 pins on the far left center of the board, about an inch from the CPU, and orriented horizontally to the long edge of the board.
6 pins on the far right upper portion of the board, arranged in an "n" fashion (that is, the space could fit 8 pins, but the bottom row center two are missing).
Thanks in advance for any ideas.<P ID="edit"><FONT SIZE=-1><EM>Edited by andrewkm on 10/13/01 00:29 AM.</EM></FONT></P>
