Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I am trying to 'Insert - Object' (a Power Point slide) into a Word document.
Usually, when I select the function, the computer seems to 'hang' for about
30 seconds, then I get an error message to the effect that Power Point is not
installed, or similar. The slide that I am trying to install opens perfectly
well - so Power Point is OK. Further, I have managed to carry out the
operation successfully on some occasions with the same document - on others
it fails for no apparent reason!
