ICS problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I have an xp host with adsl connection working fine. Client is ME (never
mind). Client sees gateway, can ping sites by name, can connect to mail
servers (but not download messages) and cannot browse pages even though it
seems to find the sites. I have removed SP2 from the host as this may have
happened at the same time. I have tried winsock fix, new IE6 sp1, adware
removed etc., firewalls off...
Any clues?
Thanks
user
Splendid
Dec 26, 2003
3,943
could the windows firewall be turned on one of your network card in the XP
machine and be configured strangely?
G
Guest
Guest
no, as I said, firewalls off...
MadMax
39
> Any clues?
> Thanks
On the ME machine,are you using "Client for Microsoft Networks" as
primary Network Logon? Using same workgroup name?Are you using Ethernet
card?Are you using a crossover cable or simple hub or wireless? Using
only TCP/IP,disable DNS and,set IP to obtain address automatically.I am
using XP Pro SP2 with ICS running-no problems.Post back.
-max
To help you stay safe see: http://www.geocities.com/maxpro4u/madmax.html
Virus cleaning +fixes see: http://www.geocities.com/maxpro4u/TechPros
Change nomail.afraid.org to neo.rr.com so you can reply by e-mail
(nomail.afraid.org has been set up specifically for
use in Usenet. Feel free to use it yourself.)
