G
Guest
Guest
I've been running my kt7-r for a long time with a TB 700@900mhz. I recently got a 1ghz (266 fsb) chip and when I put it in the board it always shows up as a 750mhz chip. I have reset the bios several times and have tried auto and manually setting the clock speed, but when I reboot it still shows 750mhz. I didn't change any other settings... I simply swapped the chips and adjusted the frequency to 1ghz and set the voltage to cpu default. Any ideas?
Thanks!
Thanks!
