[HELP] Recording With FRAPS
Hi,
Specs at Bottom
I have just bought myself a copy of Battlefield 3 and pre-ordered MW3
My aims are simple, to record gameplay, both single and multi-player
Where i have a constant high (playable + a little more) FPS and no Graphical Lag
I will be recording with a Paid Version of FRAPS.
I am willing to spend £450 over the next 3-4 months upgrading my PC, (Acer Aspire Predator Defender)
Processor: AMD Phenom(tm) 9750 Quad-Core Processor (4 CPUs), ~2.4GHz
Memory: 4096MB RAM <-- When i render on Vegas i run out of memory, even with very small edits (30Secs = still nothing)
Hard Drive: 310 GB x2 <- Hot Swappable Hard Drives
Video Card: NVIDIA GeForce GTX 460 (3D and Eco-Friendly) <-- dropping 3D for better fps and gaming in general
Monitor: Acer 26" (1920x1080)
Which of these should i improve, please supply:
Price
Name
Link
Size of Increase ( Small, Medium, Large, Must Have )
10 answers Last reply
More about help recording fraps
  1. Removed and put above, after i have found out how to edit xD ^
  2. The CPU perhaps is the one that I'd upgrade. But it's okay though.
    Maybe the GPU too. The 460 is a great card but you'll get much better performance if you pair it with another 460.
  3. I must add the 460 is a 3D and Eco-Friendly card which is not ideal
    Could you supply links to a GPU and CPU i should buy? and maybe more ram i need some for
    editing with vegas as a run out of memory. i ask as i dont know what to buy because this is my first time upgrading.
    Will you need to know my power supply?
  4. Yes, I would need to know about your PSU.
    Well, since you're probably having an AM2+ board, you'll need to upgrade to an AM3/AM3+ board.
    GIGABYTE GA-M68MT-S2
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128529
    About $55
    You won't be able to SLi though with that motherboard.
    CPU- AMD Phenom IIX4 970 Black edition
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894&Tpk=Phenom%20II%20970
    RAM- Corsair Vengeance 2X4 GB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233196
  5. I'll give you the link for a good GPU after you post your PSU. :)
    The total right now is over $270 which is about 160-170 pounds or so.
    Sorry im kinda new to looking inside my pc and things so bare with me ^^
    Two Things
    PSU? Power Supply? would this be what you want:
    Power Provided : 750 Watt
    GPU? "Speccy" says it is GF104
    I am unsure about this one - Package Socket AM2+ (940)
    Dont keep things cheap, little upgrades dont need em... i am willing to spend up to £450 (GBP)
  7. I'll provide you with a better board then. :)
    I need more info on that 750W PSU. Which brand and model? How much amps does it deliver on the +12V rails?
  8. Quote:
    raps is a universal Windows application that can be used with games using DirectX or OpenGL graphic technology.Take a screenshot with the press of a key! There's no need to paste into a paint program every time you want a new shot. Your screen captures are automatically named and timestamped.
    Thank you for taking your time to write that.. However,
    I know what it is and how it works, i need to know what i need to upgrade on my pc to allow FRAPS to keep a high fps while recording
  9. ASUS Sabertooth 990FX
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
    Price- $189
    It has support for AM3+ CPUs. But I'd stick with the Phenom IIX4
    That's a good board.
    However, do tell me if you're willing to look at a LGA 1155 board. More specifically a 2500k.
    if that's the case
    GIGABYTE GA-Z68X-UD3H-B3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128498
    Pirce- $169
    CPU
    i5 2500k
    It'smore expensive than a P IIX4 970 but it's significantly faster.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
  10. Oh, and do tel me about the brand and model of your PSU. :)
PC gaming Video Games Product
