G
Guest
Guest
I have a new system (stats below) that shuts off in the middle of doing things. It will sit there forever, but when I do certain things (copy files in explorer and Max Payne), it restarts. Max Payne is odd because the task bar shows through into the game. I have adjusted the bios setting to the lowest performance possible, and flashed the bios.
And sometimes it won't boot, and I have to try to boot it 3 times before it finally does.
All the hardware worked fine with a ASUS A7M266 and 1.4.
I have a custom HS fan setup consisting of 2 blowers. They are connected to the MB. I wonder if they are drawing too much power?
Please offer suggestions.
Athlon XP 1700
MSI K7T266 Pro2
Kingston Value Ram 256 MB x 2
IBM 40 GB HD x 2
ATI All In Wonder
No name NIC
Soundblaster Live
Intel Modem
12X DVD
16X10X40 CDRW
300W PS (not the cheap kind)
Win 98 SE
Athlon XP 1700
MSI K7T266 Pro2
IBM 40 GB HD x 2
ATI All In Wonder
No name NIC
Soundblaster Live
Intel Modem
12X DVD
16X10X40 CDRW
Win 98 SE
