Closed
BF3 Crashing Computer, Power Problem?
Like quite a few others I am having a problem with BattleField 3. It happens when I start playing Multiplayer, once I choose a map to play and it launches the game, after the loading screen when I can choose what class to play I have from 0 seconds to 5 minutes before my computer will deside to just crash on me.
What happens: when it 'crashes' everything freezes, it just gets stuck on the last frame that was displayed and at the same time my speakers make a buzzing sound (volume controlable with the volume dial on my speakers, if I turn my speakers off it stops). Nothing works; there is no BSOD I cannot Ctrl-Alt-Del, nothing. I have to just reset my computer via the reset button on my case (or hold down the power button).
My specs:
Intel Core i7 860
AMD Radeon HD 6950
Gigabyte GA-P55A-UD5
4GB 1333 (I think) RAM
and where I think the problem might be:
Cooler Master eXtreme Power Plus 650W
I have tryed updating the drivers and repairing the BF3 game via origin client (don't know if this would do anything). But as you can see nothing has helped. :(
Some other possibly usefull info:
My computer when it is not doing anything (idle):
When it crashes:
Sorry I had to take a picture of my screen but... yeah nothing works when it crashes
This has never happened to me before, I have run other games at their highest (Global Agenda, TF2, HL2, Minecraft, LF Dead, RA3) but as you can tell none of then really would require the processsing power that of BF3 at ultra. So I cannot really tell if it's BF3 itself or I have had this problem all along but nothing has really ticked it off untill a game like this came along.
BF3 Settings:
When I first ran BF3 I (naturally) set everything to its highest. I have also set everything to the lowest possible settings with VSync and it still crashes (the picture above is with BF3 at lowest w VSync)
I hope someone can help me, Thanks.
14 answers Last reply
More about crashing computer power problem
  1. Does anyone have any idea? :??:
  2. Which version of your video card are you using?
    Update and see if the problem persists.
  3. you've only got a 36amp PSU (on 12V), does anyone know how many Amps the 6950 needs?
    Just had a look at 3 600W PSU, all have 48-50amps.
  4. I've got the same PSU as he does, only his is 650W and mines a 600.
    This PSU isn't top of the line at all (my 600W). It delivers only 18A on both +12V1 and +12v2 rails. Total of 36A.
    It should be enough to power a HD 6950 though.
  5. It's not your system it's happening to a lot of people. The best guess atm is a conflict with audio drivers.
  6. I have the fix to all the crashes in bf3 :)
    Make sure to close down bf3 and origin! Origin must not be running!! Then go to your control panel, and press remove program, mark punkbuster, and delete punkbuster. A popup window appers, press finish. Then Reboot your computer. Start Origin, and then RIGHT-CLIK on bf3, and choce repair. Let it do it`s thing, and when finish, the game runs perfectly :)
    Posted by: XcsoX
    Posted by: XcsoX
  8. Glad to see that you've sorted this one out. :)
  9. Thanks :) it wasn't easy; so when it finaly pays off it feels so damn nice :) :) :)
  10. you said the screenshot is of your idle temperatures. what are the max temperatures at full load?
    is anything on your system OC'ed?
    what driver version are you running?
    errm, its fixed
  12. I haven't seen the op reply that it's fixed, so your point?
  13. been so long since the OP said anything that I thought XcsoX was the OP.
  14. How u fix it i do that delet the punk buster and repair but didnt works and i have the same problem my machine stuck and do a ugly sound and i need to restart by pc buttun >.<
PC gaming Battlefield Computers Video Games
