Power usage
Forum Old Man/Woman's Club : Other - Power usage
Hey, does anyone know how much total power a normal computer would take up? My dad always complains about leaving the computer on because of the electric bill, but does leaving the computer on for awhile really cost that much per month?
Sponsored Links
Mine not only serves as a computer, but a noise blackage system and a heater, so my dad's cool w/ mine:)
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Reply to Flamethrower205
Aww, but no one knows how much it costs? I heard from a friend that someone had run a test with their computer on for a month and the bill only came to around 10 bucks, but I don't know how much truth is in that...
Reply to crapola5
Most of them, are around 250W for power systems, and can go up to 350W if you use extreme clock speeds with very high end graphic cards.
No IMO they do not consume this much. If I am not mistaken, kilowatthour works in W*1h, so each 3-4 hours, you should be spending some cents.
Help the THGC Photo Album project by promoting this URL to your sig! http://forumz.tomshardware.com/mod [...] d=1&code=1
Reply to eden
Depends on hardware configuration... but on full load about 300W. And on idle without screen and speakers about 150W I think.
And as Flamethrower said it also helps heating the room.
My PC eats so much money that I'm in 'desperate' need of it to buy PC3500 RAM, help Svol with his OC project!
--- PM me for information.
Reply to svol
A Watt is a measurement of "power". It's a specific amount of energy (thermal, electrical, or mechanical), over the course of a specific amount of time. A Joule is a unit of energy.
Joule per second; British Thermal Unit (BTU) per second. Both are units of work, and you can convert between them.
Around here, a kilowatt hour runs about $.08 (after final taxes and those bonus "surcharges" ). A kilowatt hour is kind of redundant; there's two units of time in that derived unit. kiloJoule per second per hour; but it makes calculations a bit easier.
Say your toaster pulls 10 amps of current. 10 amps times 110 volts (Ohm's Law) is 1100 Watts; <i>or</i> 1.1 kiloWatts. Multiply that 1.100 kiloWatts by {.08 dollars per kiloWatt-hour}.
1.100kW * $.08/kW-hr ==> $.088/hr
Eighty eight cents per hour.
So, if you run that toaster for one hour, non-stop, that will cost you eighty eight cents. You just heated your house with a 1100 Watt heater, for the cost of $0.88.
On your computer, the math process is the same, just with different numbers.
If you average it out over maybe a week, your computer will pull around 250w. Your hard disk isn't being accessed constantly (for most people), not all of your ram is being used, your burner and cdrom drive aren't spinning constantly, your speakers aren't blaring.
If you use it for 12 hours a day (fragging punk @$$ llamas on the internet!!), you can bump that up to 300w.
Your montior can pull (depending on the size) upwards of 100w. 350w.
So, every 3 hours, you'll pay $.08 (actually, a little over this, but I'm rounding down to 333.33w on the computer). Sixty four cents a day.
At, or just above, $20 a month. Figure $25 a month, with heavy gaming usage.
If you shut it off at night, you can half that cost; maybe $13. If you screen-save your monitor to "standby" after 10 minutes of non-usage or so, you can probably subract a 25% off that $25.
This whole kilowatt-hour thing, by the way, is called "Unit Analysis", or "Unit Conversion", or even "Quantitative Analysis". The cornerstone of Applied Science. You'll be doing a <i>LOT</i> of this when you start taking advanced science courses.
"I personally think filesystems should be rewritten from scratch every 5 years..." --- Hans Reiser
Reply to ejsmith2
A high end PC, overclocked or not, running full cpu load 24/7 can add noticably to the power bill.
particually if like i said, overclocked or running some distributed computing task all the time.
you could offer to pay some of the bill, that might make your folks happier :smile:
<b>Pentium4 Celleron: The computing worlds Rice Car.</b>
Reply to lhgpoobaa
IIRC Watt is the power per second, while Joules is W/sec.
You said Watt is over a course of time, that is Joules, or Joules=Watts in a certain amount of time.
Also you obtain 0.088$ to pay, you said 88¢, just correcting you as it can be confusing to someone to say that! Boy 88¢ would be expensive!
Posting from the garden of Eden...
Reply to eden
Joules is work or energy. Watts is Joules/second. Work per second is defined as power.
Some day I'll be rich and famous for inventing a device that allows you to stab people in the face over the internet.
Reply to silverpig
The average joe is really only paying $4/month on their PC. We're not average though and if you keep it on 24 hours a day it'll add up as several have shown.
Nonetheless, if you turn it off at night and when you "really" aren't using it, your dad can rest assured that he's not gonna go broke.
I have the PC on quite a bit and electricity here is expensive, yet my ENTIRE electricity bill is just a bit over $20 a month for a one bedroom apt with a crappy refrigerator contributing to most of that cost.
<font color=red>
<A HREF="http://www.journals.uchicago.edu/ApJ/" target="_new">Forum Assassin</A></font color=red>
Reply to dhlucke
That's also including a second pc that's on a bit as well.
<font color=red>
Reply to dhlucke
It no maky much difference, cause electricity bill here's several hundred anyway.
- Mario Andretti
How much would my parents pay with my 5 PCs... 3 running atleast 5 hours a day.
Reply to svol
Probably the $20 something a month. It's much worse having an old refrigerator or something like the heat running. The computer isn't that bad.
<font color=red>
Reply to dhlucke
Tom's Hardware > Forum > Old Man/Woman's Club > Other > Power usage
There are 1137 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
