This is getting ridiculous. I had probs with the k7s5a and now well...:
The bios is loaded with fail safe defaults. The ram module is in Dimm1. The bios has been updated to the latest bios (Nov 17). Whenever I restart the computer, I get the C1 post code (that code means it is detecting the memory) and the computer does nothing. If I restart it again it will work. After I restart it again it will just stop at the C1 post code like before and then I have to restart it again and it will work.
Usually the C1, working, C1, working, cycle I get when resetting the computer is consistant, but sometime it will just work twice or even three times in a row, but then after I restart it will go back to where the screen is blank and C1 is all that is showing on the LED on the motherboard.
I tried putting in 3 256MB of PC2100 crucial ram (they are all the same type unbuffered, no ECC, ... ect.)Then the C1 post code was shown and I just got continuous beeps like it says here: http://www.epox.com/html/english/su...sp?Article=1041
I took all the ram out and put in one stick again like before.
Same C1 post code and continuous bios beep code.
I tried a vid card with no onboard ram, and put in all each ram module one at a time and got the same C1 post code and continuous bios beep code.
I did the same thing "tried a vid card with no onboard ram, and put in all each ram module one at a time" and then it just booted with one of the ram modules. I restarted the computer and as I expected, I got a blank screen with a C1 post code, but no beeps so I was back to where I started. I reset and it worked as usual, but reseting again gave me the same blank screen with a C1 post code on the motherboard.
It was having this problem before I updated the bios, and before I even installed an O.S.
Other notes:
<A HREF="http://forums.overclockers.ws/vb/showthread.php?s=2088e31978663eba237a267ab303b006&threadid=43938" target="_new">http://forums.overclockers.ws/vb/showthread.php?s=2088e31978663eba237a267ab303b006&threadid=43938</A>
"For anyone who has 8KHA+ with rebooting issues, you are not alone; as we have encountered whole batch of boards with the same problem. I have been in contact with EPoX last couple of days, apparently they are aware of it, and came up with a fix/solution. However, it sounds like it involves a BIOS chip replacement; not a simple BIOS update.
EPoX is overnighting me some BIOS chip as well as the tool to extract the BIOS chip to us, and I will let you guys know if it helps in resolving the rebooting problem. If it does help, those who purchased the boards from PCNUT, please contact me directly at pcnut@pcnut.com, or support@pcnut.com. If you didn't purchase the board from us, we can't help you; you will need to contact your reseller for a replacement BIOS chip."
Other notes:
