G
Guest
Guest
Installed a new A7V133 w/1.4 Athlon. I'm trying to install the HD from my old system. It's a 30 Gig HD w/3 partitions. I have formatted the first partition and tried to install Windows 2000. I load the 4 floppies without a problem, then the system reboots, and begins setup. At the beginning screen, where Windows is detecting the hardware I get a blue screen that simply says "Hardware Malfunction Please contact your vendor: System is halted" Is it a bad board? I haven't got a clue. Any input would help. Thanks
