Ok this is a bit long...
i recently replaced my motherboard (due to bios corruption) and added a second 80GB SATA hard drive.
since this replacement i have been unable to run a clean instalation of windows XP, i get a error message telling me that X or Y file cannot be copied properly, the only way to get windows to run is to select ignore and move on.
windows will run however i cannot install any games that i have tried (over 10) and severall software apps will either not install (X or Y file is corupt) or once they install they will not run. (same problem)
the only programs i can run are mozilla, bearshare, and an internet poker site software.
i have wiped my HD severall times, swapped my new motherboard, used both harddrives individually, and re-installed all drivers, and nothing works...
any ideas or assistance would be greatly appriciated...
here is my system config...
AMD Athlon XP 3000+
1 GB DDR 400
ASUS KT-600 Mobo
2 80 Gb SATA harddrives (one hitachi, one western digital)
ATI Radeon 9800 Pro 256Mb GPU
Windows XP Home edition W/t service pack 2
I have ATI Stock And a NVIDIA card
AMD Athlon XP 3000+
1 GB DDR 400
ASUS KT-600 Mobo
