Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > How Do I Test Mobo Power Circuit?
Forum Motherboards & Memory : General Motherboard - How Do I Test Mobo Power Circuit?
[I asked this basic question in 'Other Components'. I'll try the mobo-specific version of it here.....]
My system sometimes acts like it isn't plugged in. Multiple cycles of both the front-panel and rear-panel power switches do nothing. Then, ultimately, it powers up. When its dead *nothing* happens: no case fans, nothing.
How do I isolate whether its the front-panel power switch, the motherboard, or power supply?
Thanks.
Jim
jimhasel@home.com
Sponsored Links
If I had a chance to get a good working power supply from another good working machine I would try it first.
Just usual basic questions, normally asked before providing with any advice: how and when it happened you got a problem? What are your system and power supply models and general technical data?
<P ID="edit"><FONT SIZE=-1><EM>Edited by NickM on 11/11/01 05:37 PM.</EM></FONT></P>
Reply to NickM
- 0 +
I would replace the cord going to the power supply, or bend the tangs slightly on the ps. Works everytime for me.
Reply to o1die
Aha! Thanks for the idea. To reduce the cabling disruption I used the 6 year old power cord from my old computer. I completely forgot that fact. Its running now on the new power cord that came with the case. I'll see if that makes a difference.
I forget half the time to post the specifics of my system:
InWin S506 Case; 300W PSU
Athlon 1.2 GHz; 266FSB, Thermaltake 6Cu cooler
Gigabyte GA-7DXR motherboard
256MB Crucial RAM
WD 40GB 7200 RPM hard drive
Sony 32x CD-ROM
Philips 8x CD-RW
Thanks again!
Jim
Reply to Anonymous
Beware the cranky power supply!
I had similar problems...I had to hit the power switch 3 or 4 times before the comp came on. Then, one day after about a week of this, I heard a loud pop, whistle and smelled smoke: two of the capacitors on the motherboard had blown off.
It was a good excuse to upgrade though...
Reply to maxPower
- 0 +
To test the power button on the computer, use a different case. To test the power supply, use a different one... When the problem goes away, whatever you just replaced, has got to be the problem. I was having the same issues with a POS Gateway's at work. The problem turned out to the a loose wire on the power switch in the case. Once I soldered it back on, it worked like a champ. (for a gateway anyway)
Reply to Raskall
There are 1456 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
