Quick launch problem!!!!!
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I am not able to create the quick launch bar on my toolbar. I tried
everything and it is still not working. I tried creating it from every angle
and it still wont work. When I rightclick/toolbars/quicklaunch...it tells
me that
it cannot create toolbar. Does anyone know what is going on????
It used to work and then one day, nothing!
I have never had this problem before.
I appreciate the help!!!
1 answer Last reply
More about quick launch problem
  1. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    1.) Make sure the folder exists.
    \Documents and Settings\%username%\Application Data\Microsoft\Internet
    Explorer\Quick Launch
    2.) Run "regedit" from Start|Run.
    3.) Browse to
    "HKCU\Software\Microsoft\Internet Explorer\Toolbar" and click this key.
    4.) Select File-Export from the menu, and save the registry key to
    "backup.reg".
    5.) Click the
    "HKCU\Software\Microsoft\Internet Explorer\Toolbar\Explorer" key, delete all
    entries in the right pane except the (Default) value.
    6.) Click the
    "HKCU\Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser" key and
    delete all entries in the right pane except the (Default) value.
    7.) Close Registry Editor and reboot the computer.
    Regards,
    Dave Patrick ....Please no email replies - reply in newsgroup.
    Microsoft Certified Professional
    Microsoft MVP [Windows]
    http://www.microsoft.com/protect
    angle
    | me that
Microsoft Quick Launch Windows XP
