hi guys/girls
just a quick question to the electrically minded.
i have two 25cm extractor fans i am fitting in to my basement which i bought slightly 'oversized' in the hope i could run them at half speed so they are quiet but stil offer a fairly O.K. air flow over a smaller bladed model.
the fans are 34Watt at 220volts 60Hz.
as far as i understand, i simply need to add a capacitor to the circuitry in series, is that so?
i opened the casing and found:
im guessing the brown one is a 'starter' capacitor? - but i may be wrong.
it is labeled "2PW1.0V AC 300V HAN SIN".
so based on the spec, what spec capacitor should i add to the circuit to 'half' the fans speed and where in the series should it be located?
will i run into any fire risks or other problems in doing so?
many thanks to anyone who can chime in!
