Archived from groups: alt.cellular.verizon (More info?)
I activated my old Audiovox 9000 last night online.
It wouldn't receive calls (calls rang 5-6 times and went to voicemail), and
when I tried to call out, James Earl Jones told me they couldn't verify
authentication.
"Dean" <dean173@yahoo.com> wrote in message
news:L0Qwd.583$152.76@trndny01...
and
> authentication.
> I went back and put my v60s online again.
> Any ideas why I ran into this problem?
> Dean
Yep,
In fact, I did!! It said the phone had been programmed successfully.
Dean
___________________________________________
"Stanley Reynolds" <nospam_stanley_reynolds@yahoo.com> wrote in message
news:Ef2dnXnlgaw1UF7cRVn-pA@pghconnect.com...
> and
> > authentication.
> > Dean
> Did you do a *228 option 1 after web activation ?
news:nbQwd.806$EL5.699@trndny09...
> Yep,
> Dean
Well that means the system knew what to program your phone with and you put
the right number in. The only other thing I can think of is you may have
needed to wait longer for it to work.
Dean,
It happened to me last week. All I wanted to do was change from NAM1 to
NAM2. The change was easy on their part, but it wouldn't work. The system
isn't foolproof. VZ technical dep't had to help me re-program my v60.
After entering the 24-digit intialization code, all was well again. They
were very helpful.
and
> authentication.
> Dean
> and
> authentication.
> Dean
Heh, heh. You did pay your bill last month, didn't you;-)
also- it's not always a nam switch that causes it-
sometimes a phone just need to be authenticated for whatever reason. usually
seems to be an older model phone- just call cust care, ask if they can help w/
an authentication issue- or ask them to txfr you to tech support, it will take
these guys about 5 seconds to fix you up. it's not your phone ( well, not
likely anyway)
