G
Guest
Guest
Hi, i am building 2 machines up .m/b are elite k7s5a with 350w tsunami psu in case.Using a 1.4 athlon and 256mb ddr samsung ram.Heres the problem
1st m/b chip and heatsink installed,agp hd dvd and floppy.globalwin fan and ready for bootup.Go into bios and all is well.Set it to 133/133 and leave drams at spd default.Bootup fine and fdisk and format hd.All is well for an hour or so now.Following day,ready to install win98.Machine left running for 2 hours .Sat nicely at 45oC.Came back and machine gone off.Try to switch on.Wont switch on.Remove psu cable and reinsert and machine starts up.4 secs later switches off.Keeps doing this .Finally i reset the cmos and managed to get back to the bios.Set it as defaults and back to dos.Again shuts off. Hmmmm.
Decide to try the next board.
Strip down and reinstall as above.New arctic silver used.Start up the machine and goto bios.All is well and temps are low again.Not even at 100oC and off it shutsdown again.Now im puzzled if its the mainboard at all.
I wonder wether theres a compatibility problem with these boards and the 1.4
Maybe i have a dodgy psu in the new case.
Or as a last resort,some arctic silver managed to get onto the L5 on the cpu.Im lost now.Can someone please help or the boards and the 1 tower will be going back .
