Archived from groups: alt.internet.wireless (More info?)
Hi
Can anyone shed any light on a solution to this problem please?
New HP pc, I installed a Sitecom wireless pci card, everything works fine
except the pc (windows xp home) restarts instead of shutting down.
I've searched for days for a solution, I've tried everything ever posted
about windows xp shutdown problems and I'm exasperated! I've formatted the
pc about 4 times now and it's only a week old!
If i take the card out, the pc shuts down perfectly, so i know this is were
the problem lies.
If anyone can help, I'd be extremely grateful! I've got into a few extra
options on the bios by hitting f12 on startup but nothing there worked
either
"Maureen Williams" <maureen99happy@blueyonder.co.uk> wrote in message
news:GhlCd.2721$GG1.2241@text.news.blueyonder.co.uk...
> Hi
I would get a different card. On the microsoft website
they have a list of manufacturers cards that are compatible
with XP, could be the one you have is not. Sorry I dont have the link, but a
little searching at microsoft .com should show the results.
were
> the problem lies.
> either >
> Many thanks
> Maureen
Maureen Williams wrote:
> Hi
> fine except the pc (windows xp home) restarts instead of shutting
> down.
> posted about windows xp shutdown problems and I'm exasperated! I've
> formatted the pc about 4 times now and it's only a week old!
> is were the problem lies.
> extra options on the bios by hitting f12 on startup but nothing there
> worked either >
> Many thanks
> Maureen
Lets see.. Pc works fine without the card, but screws up with the card.. I
would suppose it may be the card. Why not try a different one? (come to
think of it, who is sitecomm? All I can find online is they seem to be a
european company)
I just wonder why, in your own words, you say you know the problem is not
the pc or xp, so why do you keep reformatting the hard disk/reinstall xp
etc, and refuse to use one of the many dozens of cards people use all the
time with no problems, but keep reinstalling a card that causes problems?!?!
Thanks, I'll check the microsoft site. I was using this card in an Win98
machine until last week, and initially had the same shutdown problem.
Fortunately, I found a setting in the bios that I could change and it solved
the problem. I was hoping there may be a solution similar for this machine.
Thanks again
Maureen
"Airhead" <campbell@alliancecable.net> wrote in message
news:41d9f399$0$22521$2c56edd9@news.cablerocket.com...
> > Hi
a
fine
the
> were
> > the problem lies.
> > either > >
> > Many thanks
> > Maureen
