Tom's Hardware > Forum > Systems > Compaq > need 3 drive ribbon cable
Archived from groups: alt.sys.pc-clone.compaq (More info?)
Where can I buy a 3 drive (plus the motherboard connect) 40Pin ribbon cable?
thanks in advance,
tele64
Sponsored Links
You cannot. Only 2 drives per IDE controller.
HH
"tele64" <tele64@bellsouth.net> wrote in message
news:VlClc.65095$oN1.62474@bignews5.bellsouth.net...
cable?
> thanks in advance,
> tele64
Reply to hh
HH, I don't get it....my nephew has 3 drives connected; 2 CDRW drives and
one floppy.....all with one ribbon cable!
"HH" <hahunt42@hotmail.com> wrote in message
news:fzDlc.734$Ga.549@fe25.usenetserver.com...
> HH
> cable?
> > thanks in advance,
> > tele64
Reply to Anonymous
- 0 +
No he doesn't.
news:exVlc.73807$oN1.27343@bignews5.bellsouth.net...
> > HH
> > cable?
> > > thanks in advance,
> > > tele64
Reply to dos
Not possible considering the floppy uses a smaller cable and connector
than the other two drives.
Steve Williams
and
> > HH
ribbon
> > cable?
> > > thanks in advance,
> > > tele64
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Reply to Anonymous
you're wrong.
"doS" <kobo65@hotNOTSOmail.com> wrote in message
news:109gbbv50eg0e9d@corp.supernews.com...
> No he doesn't.
and
> > > HH
ribbon
> > > cable?
> > > > thanks in advance,
> > > > tele64
Reply to Anonymous
Yes possible....
"Steve W." <me@homer.org> wrote in message
news:40983eea_6@corp.newsgroups.com...
> Steve Williams
> and
> > > HH
> ribbon
> > > cable?
> > > > thanks in advance,
> > > > tele64
Reply to Anonymous
Never on any computer I've seen since 1981. Perhaps a very, very, very,
very special model.
For a standard IDE controller, two is the limit. Now pretty much every
motherboard has two controllers. so two cables = four devices.
Tom
news:d9Xlc.26403$UG2.13725@bignews2.bellsouth.net...
> Yes possible....
> > Steve Williams
> > and
> > > > HH
> > ribbon
> > > > cable?
> > > > > thanks in advance,
> > > > > tele64
Reply to Anonymous
This group has tried to answer my question but can not....
"Tom Scales" <tomtoo@softhome.net> wrote in message
news:z5mdndGq34yd2QXdRVn-vw@comcast.com...
> very special model.
> Tom
> > Yes possible....
> > > Steve Williams
drives
> > > and
> > > > > HH
> > > ribbon
> > > > > cable?
> > > > > > thanks in advance,
> > > > > > tele64
Reply to Anonymous
- 0 +
Again, the floppy drive uses a floppy controller, not the IDE controllers,
and a 34-conductor cable. IDE cables are 40-conductor (wider). On a standard
PC, there are two ide controllers (primary and secondary). Each can handle 2
devices. Period.
HH
news:6KXlc.71122$7a5.17429@bignews6.bellsouth.net...
> > very special model.
> > Tom
> > > Yes possible....
connector
> > > > Steve Williams
> drives
> > > > and
> > > > > > HH
> > > > ribbon
> > > > > > cable?
> > > > > > > thanks in advance,
> > > > > > > tele64
Reply to hh
Yes, the group has been quite polite in providing an answer--you just don't
like the answer. I vote with the others--I don't think more than two IDE on a
channel will work, but never having tried it, and being of rather limited
knowledge and experience, I'll not say its impossible. But I've never seen a
four connector IDE ribbon data cable (SCSI, yes, but not IDE). And I can't
imagine mixing floppy and IDE cables. If a four connector IDE exists it should
be easy to find doing a Goggle search--so search there rather than insult this
group. And I know of a local cable fabricator that could make one for you if
you insist--but I'd bet its a waste of your money.
Dale
Reply to Anonymous
On Tue, 4 May 2004 21:19:47 -0400, "tele64" <tele64@bellsouth.net>
wrote:
>you're wrong.
Are you sure? Unless your son uses SCSI setup and has SCSI disk drive
(is there such thing as internal SCSI floppy drive??), there is no way
a floppy drive and hard drive can be on the same cable. Take another
look, maybe it only appeared to be one cable is in fact 2 cables
positioned close together so to fool some nOObs like you.
Better yet, prove you're right by taking picture oif his computer and
posting it so we could look for ourselves.
To reply, replace digi.mon with tds.net
Reply to Anonymous
Here is a simple question for you. What make and model is this computer?
Steve Williams
very,
> > very special model.
every
> > Tom
> > > Yes possible....
connector
> > > > Steve Williams
> drives
> > > > and
> > > > > > HH
40Pin
> > > > ribbon
> > > > > > cable?
> > > > > > > thanks in advance,
> > > > > > > tele64
World!
Reply to Anonymous
See, mr teletubbie64 ...
Actually, there is 1 way, and possilby 2, to get a floppy drive to work on a
40pin IDE cable, and controller.
The first that I am absolutely positive of ... is if that drive is an LS120
drive. While not strictly a floppy drive, it will do 1.44 floppies, and
120M disks. To the neophyte, the LS120 can easily be mistaken for a floppy
from just looking at the outside of the computer. It runs on the IDE ribbon
cable. I can provide pictures for those who have not seen them... I am using
2 of them in my computers now.
The second, and this one I am not sure about because I have never done it,
would be if that 'floppy" drive was actually a Zip drive. I am not sure
about the old Zip 100, but I do know that the Zip 250 comes in an ATAPI
(read as IDE) model Again, it would be utter ignorance to confuse the two.
Based on those two exceptions, as they are by no means "standard" equipment
on most consumer models of machines, we can see where a device that could
even remotely be mistaken for a floppy disk could rightfully be found on a
40pin cable.
(anyone that thinks this guy is a superstar should check the
a.s.pc-clone.compaq.servers group... I kill filed this genius.)
LC (aka NuTs)
> > HH
> > cable?
> > > thanks in advance,
> > > tele64
Reply to Anonymous
On Wed, 5 May 2004 03:38:04 -0500, "NuT CrAcKeR"
>40pin cable.
I'm still pretty sure you can't have more than 2 IDE drives to the
same cable. So even if it was an LS120 or Zip drive, 3 isn't quite
possible.
FWIW there are 2 versions of 100MB Zip drive. The original one used
nonstandard design and required special driver to make it work and the
newer version used standard IDE protocol and can work.
Reply to Anonymous
You are correct, you can only connect two devices per cable. He
probably saw a scsi cable.
>>40pin cable.
> possible.
Reply to Anonymous
My post was not to suggest that there were 3 devices on an IDE cable, but
was made to show 2 possible inaccurate interpretations of floppy drives on
an IDE cable. Call it splitting hairs, but it seems like a signicicant
difference to me.
LC
"Impmon" <impmon@digi.mon> wrote in message
news:r64i90d8vl08pfpfvtkf7mf6pvqhno01ld@4ax.com...
equipment
could
a
> >40pin cable.
> possible.
Reply to Anonymous
Sir, I did not insult anyone until any I received an insult. I asked a
simple question and not one person directed me to the "real" answer. An IDE
card....
"DEJ57" <dej57@aol.com> wrote in message
news:20040504222143.22258.00000713@mb-m01.aol.com...
don't
on a
seen a
should
this
if
> Dale
Reply to Anonymous
- 0 +
Uh, an IDE card will not allow 3 drives on a cable any more than your
onboard IDE controller will, so in actuality, it is not an answer either.
Also, many PCs and their OSs react strangely to any more than 4 IDE devices
total.
Dale was politely making a good point.
HH
news:_3hnc.63463$cb.7383@bignews1.bellsouth.net...
IDE
> card....
> don't
IDE
> on a
limited
> seen a
can't
> should
insult
> this
you
> if
> > Dale
Reply to hh
Show us the "first insult".
The PCI card will not allow three either.
Tom
IDE
> card....
> don't
IDE
> on a
limited
> seen a
can't
> should
insult
> this
you
> if
> > Dale
Reply to Anonymous
>total.
Not quite. With a second IDE card, you could add 4 more devices.
I've done this before with Win 3.1 and a pile of 120MB hard drives.
As long as the correct drivers are used, no odd behavior should
happen. It's not common though as for most people, 2 ports and 4
drives are usually enough.
The only possible issues with multiple IDE cards is the boot order.
Onboard IDE generally have boot drives only but if there's no onboard
IDE or if it's been disabled and you have 2 or more IDE cards,
figuring which card get sthe boot priority would require a bit of
trial and error.
Yes he was. There is simply no way to get 3 or more IDE devices on
the same IDE port. The OP was being a jerk for insisting the
impossible was possible without closely checking for what it really
was. (SCSI? Or 2 separate cables held together so it appears as one
cable?)
Reply to Anonymous
- 0 +
Uh, I was referring to non-ancient OSs. I've seen the squirrelly behavior
with more than 4 IDE devices in Win 95, 98, Me and even 2000 and XP. Raid
controllers are another matter. A standard dual channel IDe controller and a
raid controller often can co-exist peacefully.
HH
news:q8pt9097ikun7dg6km5853digi5ijrfm0t@4ax.com...
devices
> >total.
> trial and error.
> cable?)
Reply to hh
Funny I don't have any problem with my current system: onboard IDE
with 80GB primary, 60GB slave (boot drive), DVD-ROM and DVD burner and
I have a plain vanilla ATA133 card added with 3x 200GB hard drives.
The only odd problem I had in the past 6 months was that one of the
200GB hard drive mysteriously unformatted itself but that was probably
because the file table was being written when a power failure happened
and corrupted the partition data.
Oh yeah I have XP with SP1, older XP can't handle 200GB drives anyway.
Reply to Anonymous
The group has consistently and correctly answered your question, you simply
refuse to accept the reply you've received!
Regards,
James
Vist the NEW Thinkpad Forums: http://forum.thinkpads.com
Reply to Anonymous
First, the other postings are correct. A standard IDE channel handles two, and
no more than two, devices. I have been in this business for many many years,
and I have torn apart, serviced, or built thousands of computers. NEVER have I
seen a 3-device 40-pin IDE cable. If it does exist, it also requires a
non-standard IDE controller of some sort. IDE drives have exactly two device
settings: master & slave. So no more than two devices per cable. SCSI
controllers support up to 7, or even 15, devices depending on the type of SCSI
you have. But SCSI uses 50-pin or 68-pin cables, not 40-pin.
Second, you can add PCI IDE controller cards to a system to expand the number of
IDE channels beyond the usual primary and secondary. I have seen systems with
four IDE channels, two devices each, for a total of eight IDE devices. Even
more are possible.
Third, especially if the system is a Compaq, there is the possibility that the
"floppy" drive is/was an LS120 drive with an IDE connector. LS120 reads and
writes both its own 120MB disk and standard 1.44MB floppy diskettes. A system
with three IDE devices would customarily use two IDE channels and have two
cables.
Rather than simply denying responses, as in the past, how about identifying the
IDE controller card (manufacturer and model) which uses a 3-device cable and
allows 3 devices to be attached? Thanks... Ben Myers
>thanks in advance,
>tele64
Reply to Anonymous
You're a n00b. It's not nOOb. It's n00b. Sorry. I just had to say it.
news:pekg901mk48dcarfb3f5m3essbi7c6soqi@4ax.com...
> wrote:
>>you're wrong.
Reply to Anonymous
You sure that nOOb isn't just an overweight n00b?
"Ryan 8088" <the8088er@sbcglobal.net> wrote in message
news:6Tgpc.8827$OF7.6788@newssvr24.news.prodigy.com...
> > wrote:
> >>you're wrong.
Reply to Anonymous
Good point. He's prolly fat as a telly.
in message
news:4eGdncjUXYWEGTvdRVn-sw@comcast.com...
overweight n00b?
wrote in message
message
| > > wrote:
| > >>you're wrong.
ourselves.
tds.net
Reply to Anonymous
you're wrong
message
news:W8Xlc.26391$UG2.20874@bignews2.bellsouth.net...
| you're wrong.
in message
| > No he doesn't.
wrote in message
| and
cable!
in message
IDE controller.
| > > > HH
wrote in message
| ribbon
| > > > cable?
| > > > > thanks in advance,
| > > > > tele64
Reply to Anonymous
news:PRMpc.27384$_u5.4497@newssvr22.news.prodigy.com...
> in message
> overweight n00b?
> wrote in message
> message
> | > > wrote:
> | > >>you're wrong.
Well, there is such a device as an internal SCSI floppy
but I've only seen them in older Sun Sparc hardware.
I'd be very surprised to see one in a Compaq consumer
product.
I'd go with this poster. You in fact have two cables
which can be hard to see when they're jammed in
to tight areas.
> ourselves.
> tds.net
Herb Stein
herb@herbstein.com
Reply to Anonymous
There are 852 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
