MAJOR DEFRAG PROBLEMS PLEASE HELP
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
i have a huge problem with trying to defrag my pc. Firstly a pop up
continually appears stating that i have low disk space available on my pc.
So from this i am continually doing a disk clean up. When i have tried to
defrag my pc too it fails to do so and a message appears stating it has
failed to create and empty document. I have not got a clue what that means.
I have tried everything i can to get this pc to defrag but it just isnt
working. I am hoping that by defragging my pc i will not continually get a
pop up stating that i have low disk space available. Can anyone help me with
this matter. Any help is greatly appreciated
2 answers Last reply
More about major defrag problems help
  1. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Hi Jane,
    Open My Computer and right click on the drive in question then select
    properties.
    How much free disk space is there compared to drive size?
    In the mean time go to C:\Documents and Settings\User_Name\Local
    Settings\Temp
    and empty it's contents. A reboot may be necessary to remove all files
    and folders.
    Right click on the IE icon on the desktop and select properties and
    click on Delete Files under "Temporary Internet Files" and again with
    a check mark on "Delete all offline contents". Next click on Settings
    in the same section and reduce the "Amount of disk space to use".
    With a broadband connection 20mb's should be sufficient.
    Regards,
    Bert Kinney [MS-MVP DTS]
    http://dts-l.org/
    > Firstly a pop up continually appears stating that i have
    > low disk space available on my pc. So from this i am
    > stating it has failed to create and empty document. I
    > have not got a clue what that means. I have tried
    > isnt working. I am hoping that by defragging my pc i
    > will not continually get a pop up stating that i have low
    > disk space available. Can anyone help me with this
  2. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Have you scanned your computer for spyware?
    Spyware can fill your disk as fast as you can clean it up.
    Ted Zieglar
    "JANE" <JANE@discussions.microsoft.com> wrote in message
    news:90C552EA-E886-41D8-8033-FB8A321DDBB0@microsoft.com...
    > means.
    > a
    > with
Defragment Microsoft Disk Space Windows XP
