System Info; Msinfo32.exe; XP Sp 2
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I have Xp Home Edition Sp 2.
I recently noticed that System Information (or Msinfo32.exe) doesn't 'run'
when activated; rather "Help & Support" is launched. It used to work OK.
A quick search of websites suggests the problem is a deleted 'index.dat'
file contained in a sub-folder of 'WINDOWS/PCHEALTH'. The only suggested fix
I can see is a clean re-install of Xp.
Is this missing index.dat file really the cause of the problem ? If so, is a
clean re-install the only fix (or can I get an appropriate generic index.dat
file from somewhere ?) ?
Or,.... is the problem to do with Sp 2 ?
I would welcome advice.
Many Thanks.
Greetings from England
11 answers Last reply
More about system info msinfo32
  1. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Hi,
    Here are a couple of links that should fix the problem.
    Fix WinXP Help after running Easy Cleaner
    http://www.dougknox.com/xp/scripts_desc/fixwinxphelp.htm
    Troubleshooting Windows XP, Tweaks and Fixes for Windows XP
    http://www.kellys-korner-xp.com/top10faqs.htm
    Regards,
    Bert Kinney [MS-MVP DTS]
    http://dts-l.org/
    > Msinfo32.exe) doesn't 'run' when activated; rather "Help
    > deleted 'index.dat' file contained in a sub-folder of
    > 'WINDOWS/PCHEALTH'. The only suggested fix I can see is a
    > problem ? If so, is a clean re-install the only fix (or
    > can I get an appropriate generic index.dat file from
    > somewhere ?) ?
    > Many Thanks.
  2. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Hi Bert. Thanks for this, but 'Help & Support' is working fine - no
    problems. The problem is 'System Information' or 'Msinfo32.exe', however
    they are invoked (except Msinfo32.exe with certain command line switches) do
    NOT run - instead they invoke 'Help & Support'.
    I've tried an Xp repair install and then re-installed Sp2, but this hasn't
    solved the problem. I'm reluctant to try the suggestions on your links when
    the 'problem' doesn't seem to be the one for which the solutions are
    designed.
    "Bert Kinney" wrote:
    > Hi,
    > Regards,
    > http://dts-l.org/
    > > somewhere ?) ?
    > > Many Thanks.
  3. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    First. Set Hidden files and folders to display.
    Start | Settings | Control Panel | Folder Options | View tab
    Check:
    ? Display the contents of system folders
    ? Show hidden files and folders
    UNCheck:
    ? Hide protected operating system files
    Apply | OK
    [[Hidden files and folders will appear dimmed to indicate they are not
    typical items.]]
    Second. Paste this in the Start | Run box...
    C:\WINDOWS\PCHealth\HelpCtr\OfflineCache
    Click OK.
    Look for a file called index.dat. Is one there? If not, remove the 123
    from my E-mail address and E-mail me I'll send you a copy of the index.dat
    file.
    Or if you like get a copy from a friend.
    There a work arounds, but you are probably missing
    C:\WINDOWS\PCHealth\HelpCtr\OfflineCache\index.dat
    I fixed this on my machine a couple of weeks ago.
    Hope this helps. Let us know.
    Wes
    In news:62067605-CA0A-4C4B-9E58-6B810F0E4BE8@microsoft.com,
    englishman <englishman@discussions.microsoft.com> hunted and pecked:
    > however they are invoked (except Msinfo32.exe with certain command
    > line switches) do NOT run - instead they invoke 'Help & Support'.
    > hasn't solved the problem. I'm reluctant to try the suggestions on
    > your links when the 'problem' doesn't seem to be the one for which
    > the solutions are designed.
    >> Hi,
    >> Regards,
    >> http://dts-l.org/
    >>> somewhere ?) ?
    >>> Many Thanks.
  4. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Wesley
    Thanks for your response - there is no 'index.dat' file - I'll email to
    request one.
    > Check:
    > Â? Display the contents of system folders
    > Â? Show hidden files and folders
    > UNCheck:
    > Â? Hide protected operating system files
    > Apply | OK
    > typical items.]]
    > Click OK.
    > file.
    > Wes
    > >> Hi,
    > >> Regards,
    > >> http://dts-l.org/
    > >>> somewhere ?) ?
    > >>> Many Thanks.
  5. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    It's on the way. Let us know, here how it works out.
    Wes
    In news:D011B607-C276-4349-A3C4-2B09F555F825@microsoft.com,
    > Wesley
    > to request one.
    >> Check:
    >> UNCheck:
    >> Apply | OK
    >> not typical items.]]
    >> Click OK.
    >> 123 from my E-mail address and E-mail me I'll send you a copy of the
    >> index.dat file.
    >> Wes
    >>>> Hi,
    >>>> Regards,
    >>>> http://dts-l.org/
    >>>>> somewhere ?) ?
    >>>>> Many Thanks.
  6. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Wesley
    Many thanks for the 'index.dat' file - it completely solves the problem !
    > Wes
    > > Wesley
    > > to request one.
    > >> Check:
    > >> � Display the contents of system folders
    > >> � Show hidden files and folders
    > >> UNCheck:
    > >> � Hide protected operating system files
    > >> Apply | OK
    > >> Click OK.
    > >> index.dat file.
    > >> Wes
    > >>>> Hi,
    > >>>> Regards,
    > >>>> http://dts-l.org/
    > >>>>> somewhere ?) ?
    > >>>>> Many Thanks.
  7. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    I love it whan a plan comes together.
    Keep having fun! :-)
    Wes
    MS-MVP Windows Shell/User
    In news:DFC7A741-942B-4D26-B913-761ADF256600@microsoft.com,
    > Wesley
    > problem !
    >> Wes
    >>> Wesley
    >>> to request one.
    >>>> Check:
    >>>> UNCheck:
    >>>> Apply | OK
    >>>> Click OK.
    >>>> the 123 from my E-mail address and E-mail me I'll send you a copy
    >>>> of the index.dat file.
    >>>> Wes
    >>>> pecked:
    >>>>> no problems. The problem is 'System Information' or
    >>>>> 'Msinfo32.exe', however they are invoked (except Msinfo32.exe
    >>>>> with certain command line switches) do NOT run - instead they
    >>>>> this hasn't solved the problem. I'm reluctant to try the
    >>>>> suggestions on your links when the 'problem' doesn't seem to be
    >>>>> the one for which the solutions are designed.
    >>>>>> Hi,
    >>>>>> Regards,
    >>>>>> http://dts-l.org/
    >>>>>>> somewhere ?) ?
    >>>>>>> Many Thanks.
  8. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Nicely done Wesley. Any idea what causes the deletion of the
    index.dat file?
    Regards,
    http://dts-l.org/
    > In
    > and pecked:
    >> Wesley
    >>> Wes
    >>> In
    >>> hunted and pecked:
    >>>> Wesley
    >>>> file - I'll email to request one.
    >>>>> View tab Check:
    >>>>> UNCheck:
    >>>>> Apply | OK
    >>>>> indicate they are not typical items.]]
    >>>>> Click OK.
    >>>>> not, remove the 123 from my E-mail address and E-mail
    >>>>> me I'll send you a copy of the index.dat file.
    >>>>> Wes
    >>>>> In
    >>>>> hunted and pecked:
    >>>>>> working fine - no problems. The problem is 'System
    >>>>>> Information' or 'Msinfo32.exe', however they are
    >>>>>> 'Help & Support'.
    >>>>>> re-installed Sp2, but this hasn't solved the
    >>>>>>> Hi,
    >>>>>>> problem.
    >>>>>>> Windows XP
    >>>>>>> Regards,
    >>>>>>> http://dts-l.org/
    >>>>>>>> a deleted 'index.dat' file contained in a
    >>>>>>>> suggested fix I can see is a clean re-install of
    >>>>>>>> Xp.
    >>>>>>>> the problem ? If so, is a clean re-install the
    >>>>>>>> index.dat file from somewhere ?) ?
    >>>>>>>> Many Thanks.
  9. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Hi Bert,
    In my case, SWAG, Index.dat Suite. Index.dat Suite finds all the index.dat
    files and sets up a batch file to delete them on boot. I don't know for
    sure that Index.dat Suite is the culprit, in my case, but it's the most
    likely suspect.
    SWAG. Some sort of TIF cleaner is probably to blame in many other cases.
    The index.dats in the Temporary Internet Files recreate themselves so, no
    problem. The index.dat file in C:\WINDOWS\PCHealth\HelpCtr\OfflineCache
    doesn't ever get recreated. I changed mine to Read-only and have a zipped
    backup. :-)
    Vampirefo actully discovered that the missing index.dat was causing the
    msinfo32 problem. Kelly sent me a copy of the file and I copied it to the
    appropriate place and my msinfo32 problem was over.
    Wes
    In news:uoXXVfE$EHA.2804@TK2MSFTNGP15.phx.gbl,
    Bert Kinney <bert@NSmvps.org> hunted and pecked:
    > index.dat file?
    > Regards,
    > http://dts-l.org/
    >> In
    >> and pecked:
    >>> Wesley
    >>>> Wes
    >>>> In
    >>>> hunted and pecked:
    >>>>> Wesley
    >>>>>> View tab Check:
    >>>>>> UNCheck:
    >>>>>> Apply | OK
    >>>>>> Click OK.
    >>>>>> Wes
    >>>>>> In
    >>>>>> hunted and pecked:
    >>>>>>> 'Help & Support'.
    >>>>>>>> Hi,
    >>>>>>>> problem.
    >>>>>>>> Windows XP
    >>>>>>>> Regards,
    >>>>>>>> http://dts-l.org/
    >>>>>>>>> Xp.
    >>>>>>>>> Many Thanks.
  10. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Thanks for the info Wesley, I am sure this will come in handy in the
    future.
    Regards,
    http://dts-l.org/
    Wesley Vogel wrote:
    > Hi Bert,
    > all the index.dat files and sets up a batch file to
    > delete them on boot. I don't know for sure that
    > most likely suspect.
    > many other cases.
    > themselves so, no problem. The index.dat file in
    > C:\WINDOWS\PCHealth\HelpCtr\OfflineCache doesn't ever get
    > backup. :-)
    > was causing the msinfo32 problem. Kelly sent me a copy
    > of the file and I copied it to the appropriate place and
    >> of the index.dat file?
    >> Regards,
    >> http://dts-l.org/
    >>> In
    >>> and pecked:
    >>>> Wesley
    >>>>> Wes
    >>>>> In
    >>>>> hunted and pecked:
    >>>>>> Wesley
    >>>>>>> View tab Check:
    >>>>>>> UNCheck:
    >>>>>>> Apply | OK
    >>>>>>> Click OK.
    >>>>>>> file.
    >>>>>>> Wes
    >>>>>>> In
    >>>>>>> hunted and pecked:
    >>>>>>>> 'Help & Support'.
    >>>>>>>>> Hi,
    >>>>>>>>> problem.
    >>>>>>>>> Windows XP
    >>>>>>>>> Regards,
    >>>>>>>>> http://dts-l.org/
    >>>>>>>>>> work OK.
    >>>>>>>>>> is a deleted 'index.dat' file contained in a
    >>>>>>>>>> Xp.
    >>>>>>>>>> of the problem ? If so, is a clean re-install the
    >>>>>>>>>> Many Thanks.
  11. Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
    Wes
    In news:ehv%23TXR$EHA.3504@TK2MSFTNGP12.phx.gbl,
    > future.
    > Regards,
    > http://dts-l.org/
    > Wesley Vogel wrote:
    >> Hi Bert,
    >> many other cases.
    >> backup. :-)
    >>> Regards,
    >>> http://dts-l.org/
    >>>> In
    >>>> and pecked:
    >>>>> Wesley
    >>>>>> Wes
    >>>>>> In
    >>>>>> hunted and pecked:
    >>>>>>> Wesley
    >>>>>>>> View tab Check:
    >>>>>>>> UNCheck:
    >>>>>>>> Apply | OK
    >>>>>>>> Click OK.
    >>>>>>>> file.
    >>>>>>>> Wes
    >>>>>>>> In
    >>>>>>>> hunted and pecked:
    >>>>>>>>> 'Help & Support'.
    >>>>>>>>>> Hi,
    >>>>>>>>>> problem.
    >>>>>>>>>> Windows XP
    >>>>>>>>>> Regards,
    >>>>>>>>>> http://dts-l.org/
    >>>>>>>>>>> work OK.
    >>>>>>>>>>> Xp.
    >>>>>>>>>>> Many Thanks.
Support Microsoft Windows XP
