G
Guest
Guest
I've just built a new system with the Gigabyte GA-7VTXH motherboard. I was going to move my old Adaptec AHA-2940AU PCI SCSI controller from my old system into the new so I could continue to use my SCSI devices. However, when the Windows XP hardware wizard attempts to install the device, it errors out with the message "Cannot install this hardware, the data is invalid". Since this was the only PCI card I had installed, I decided to try another one. I removed the Adaptec card, and then installed a sound blaster live pci sound card (note: I disabled the on board sound chip in order to perform this test). Once again I received the same error message. I am now concerned that something may be set wrong in the bios for the PCI. Any ideas as to what might be causing this problem?
