Archived from groups: alt.internet.wireless (More info?)
Hi,
I'm having ongoing issues with WinXP SP2 dropping my home WLAN connections.
Depending on the client NIC, it can happen anywhere from a few times a day
to every few minutes, and only under WinXP. I've left the Orinoco card
attached, running under Linux, for days without issue.
I've got 4 different client NICs: Sony Vaio laptop with built-in Centrino
PRO/Wireless 2200BG NIC, Microsoft MN-720 802.11g PC Card, D-Link DWL-650+
11b PC Card, and Lucent Orinoco Gold 11b PC Card. And I recently upgraded
my AP
from a Linksys WAP11 v1.1 to a Motorola WR850G.
With the old WAP11, the Centrino and D-Link NICs would occasionally drop the
connection and then immediately recover it. The Orinoco seemed to be better
and wouldn't drop it; I didn't have the MN-720 at the time so that was not
tested with the WAP11.
Now that I have the WR850G, I get a high rate of disconnects. The Centrino
NIC is ridiculous, dropping the connection (and immediately recovering)
about every 2-5 minutes. Things get progressively better with the D-Link
and Orinoco, and the Microsoft adapter is the best, probably because it has
a Broadcom chipset in it which is most compatible with the Broadcom chip in
the WR850G. The MN-720 will only drop the connection 1-2 times per day.
I'm mostly interested in solving the Centrino issues, as that laptop is my
main machine. In pursuit of a solution for it, I downloaded two updated
drivers from Intel's site (an 8.x and a 9.x), and none helped. I've left it
with driver v9.0.1.9 for now.
Other interesting facts:
* I've tried disabling WZC after establishing a connection, but this seems
to have no effect for me.
* The profile for my home network is properly setup, with the proper WEP
and authentication settings. And yes, 802.1x is disabled.
* If you leave up the Wireless Network Connection status window, you will
see the speed progressively drop from 54mbps to 2 or 1mbps before it
disconnects, even though signal strength is high!
* We have 5.8Ghz phones in the house (although I can't say what my
neighbors have).
* I do live in a high-density area, and there are about 10 or so other
wireless networks nearby. However, I'm careful to select channels to
minimize interference. I try to re-scan my house every couple of months.
There are so many factors that can go into why wireless connections drop
that I realize it is hard to diagnose. But surely someone else has
encountered these issues. And there has to be a fix, or I don't think M$
will be doing themselves any favors by leaving this situation alone.
"Jonathan" <jonathanNO@SPAMsprintmail.com> wrote in message
news:e5KdnctvPoiMuEHcRVn-uw@speakeasy.net...
> Hi,
connections.
a day
card
Centrino
DWL-650+
upgraded
> my AP
drop the
be better
was not
Centrino
recovering)
D-Link
it has
chip in
day.
is my
updated
left it
this seems
proper WEP
you will
Signal strength can be high and the BER can be high. Usually the only
reason the connection speed
drops is because of one of these two. If you show great strength then
that leaves errors as a suspect.
I have a centrino 2200 bg with a linksys wap54g and it has never
dropped. (fingers crossed).
I have a suspicion,,, not confirmed but, I think there are timing
issues causing alot of disconnect problems,
especially between devices and chips of different manufacturers.
> neighbors have).
other
to
months.
drop
think M$
> TIA,
> Jonathan
There is a Wireless "Quality of Service" service in Windows XP that has
been rumored to knock the speed down if errors are encountered, but it
never goes back up... ultimately leaving you with zero speed.
I disabled the QoS service in the service panel, Set the reserved portion
to 0 in the group policies, and uninstalled the QoS from my card's network
properties. The Earthlink page suggests reducing the bandwidth to zero,
says nothing about the service panel, and says to enable the NIC (which I
didn't do).
<http://support.earthlink.net/mu/1/psc/img/walkthroughs/windows_XP/6800.psc.html>
Further.net suggests just removing it from the NIC:
<http://forums.furthurnet.org/viewtopic.php?p=995&sid=69055b9e626a90c2c3db54247049f12e>
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Ultimately, that didn't work. I moved the SMC7004WFW to a place where it
only connects with Win2000 clients, and put a Netgear WGR614v4 in the
previous location. Life is good. No disconnects at all.
>> Hi,
>> connections.
Problem with XP/SP2 & Wireless networks.. It doesn't actually drop the
connect, it just drops the visual indicators of a connect (like stuff in
explorer or search).. Links on the desktop and progs that use another
machine are not effected.. only the visual indicators.
No fix that I know of, but it's been driving many of us nuts for weeks.
"Peter Pan" <Marcs1102NOSPAM@HotmailNOSPAM.com> wrote in message
news:3433khF45l52pU1@individual.net...
> >> Hi,
> >> connections.
Actually, my case could be different from yours, but I am getting actual
disconnects. I use SSH to remotely login to several Unix servers, and
everytime one of these drops occurs, I lose every one of my SSH sessions.
Highly irritating!
<dold@XReXXOldXp.usenet.us.com> wrote in message
news:crhki5$vml$1@blue.rahul.net...
portion
Well thanks for the QoS tip anyway. I will try it regardless, as it is
something I haven't explored yet.
"Airhead" <campbell@alliancecable.net> wrote in message
news:41dc4e80$0$22514$2c56edd9@news.cablerocket.com...
> > Hi,
> connections.
> a day
> card
> Centrino
> DWL-650+
> upgraded
> > my AP
> drop the
> be better
> was not
> Centrino
> recovering)
> D-Link
> it has
> chip in
> day.
> is my
> updated
> left it
> this seems
> proper WEP
> you will
Hmmm. Is there some way to figure out if the BER is the cause? Would the
client be able to log the BER periodically so I could keep tabs on it, and
possibly spot patterns? I'm sure logging is not on by default though.
Jonathan wrote:
> Hi,
> connections. Depending on the client NIC, it can happen anywhere from
> a few times a day to every few minutes, and only under WinXP. I've
> left the Orinoco card attached, running under Linux, for days without
> issue.
> Centrino PRO/Wireless 2200BG NIC, Microsoft MN-720 802.11g PC Card,
> D-Link DWL-650+ 11b PC Card, and Lucent Orinoco Gold 11b PC Card.
> And I recently upgraded my AP
> drop the connection and then immediately recover it. The Orinoco
> seemed to be better and wouldn't drop it; I didn't have the MN-720 at
> the time so that was not tested with the WAP11.
> Centrino NIC is ridiculous, dropping the connection (and immediately
> recovering) about every 2-5 minutes. Things get progressively better
> with the D-Link and Orinoco, and the Microsoft adapter is the best,
> probably because it has a Broadcom chipset in it which is most
> compatible with the Broadcom chip in the WR850G. The MN-720 will
> is my main machine. In pursuit of a solution for it, I downloaded
> two updated drivers from Intel's site (an 8.x and a 9.x), and none
> helped. I've left it with driver v9.0.1.9 for now.
> seems to have no effect for me.
> WEP and authentication settings. And yes, 802.1x is disabled.
> will see the speed progressively drop from 54mbps to 2 or 1mbps
> before it disconnects, even though signal strength is high!
> neighbors have).
> other wireless networks nearby. However, I'm careful to select
> channels to minimize interference. I try to re-scan my house every
> couple of months.
> drop that I realize it is hard to diagnose. But surely someone else
> has encountered these issues. And there has to be a fix, or I don't
> think M$ will be doing themselves any favors by leaving this
> situation alone.
> TIA,
> Jonathan
Broadcast SSID. You didn't mention if you do or not. It is reported to
solve problems like yours. There are two settings to review in the
computer wireless settings: make sure your connection is the only
preferred connection entry - even an usused entry can cause problems in
XP SP2 although I never saw a problem in SP1; uncheck Automatically
connect to non-preferred networks in the advanced properties. If you
use Shared key, try Open key in the router. Shared key is squirrely on
my -b system with the Intel mini-pci -b centrino wireless. Open key is
rock solid. You might also change the default channel to 1,2,3 or
11,10,9 and see if that helps.
>>> Hi,
>>> connections.
I'm aware of the disappearing visual indicators issue, but I am having the
same problem w/ XP SP2 and am getting actual disconnects, with no browser or
email client connectivity. My machine has a Linksys wireless-g card (WMP54G)
and I'm connected to a Linksys wireless AP (WRT54G). Latest
drivers/firmware, etc. I really despise Microsnot.
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news:nuydnRTzfpsy8EHcRVn-gQ@comcast.com...
> Jonathan wrote:
> > Hi,
> > issue.
> > neighbors have).
> > couple of months.
> > situation alone.
> > TIA,
> > Jonathan
> Q
Hmmm, I do have Broadcast SSID turned off, so I'll have to turn it back on
and see if that fixes it.
I'm already setup with your other suggestions: Only one preferred network,
and Automatically Connect to Non-Preferred Networks is unchecked. And I am
using Open authentication.
> Hi,
connections.
> my AP
the
better
Centrino
has
in
it
seems
> neighbors have).
> TIA,
> Jonathan
Well I've tried several of the suggestions listed but nothing's improved
(yet). I tried enabling SSID broadcasting, and that didn't help. So I
turned it back off and disabled QoS and M$ File & Print Sharing on the
Centrino interface; no help either. I then additionally unchecked "AEGIS
Protocol (IEEE 802.1x)" and that didn't help. So now I've restored those
settings and I've got to figure out what my next plan is.
Thanks for all the ideas though, it's given me a lot to think about.
