Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > dial-up connection keeps popping up when I have a Cable co..
Forum Wireless Networking : Wireless General Discussions - dial-up connection keeps popping up when I have a Cable co..
Archived from groups: alt.internet.wireless (More info?)
I connect to the Internet with Comcast cable Modem. Always On!
I have set up a Wireless network on my two computers at home. One is a
desktop, the other a laptop. The desktop is wired to the Netgear WGR614, the
laptop connected with the Netgear WG511 PC Card. These seemed to work good.
I then set up File & Printer Sharing between the two computers. That works
good.
But, since I set up Sharing between the computers, the Windows Dial-up
connect box pops up. Each time I go into the connection settings and choose
to "Never dial a connection" but it will not stick. It keeps changing back
to "Dial whenever a network connection is not present". This is getting
aggravating.
Any idea why this has started happening? Any idea how to fix this?
Thanks,
John
Sponsored Links
"L'l John" <je_norrisstopspam@hotmail.com> wrote in message
news:fJydncDGHOjj3EHcRVn-rw@comcast.com...
the
good.
> good.
choose
> aggravating.
> Thanks,
> John
First off, what version of Windows do you have? NT/98/Me/2K/XP?
I'm far from a Windows expert, but have you gone through the Internet
connection wizard setup to tell it you now have a LAN that has an Internet
connection? You can find it in IE in Tools -> Internet Options... ->
Connections and then click the Setup button.
good luck,
Jonathan
Reply to Jonathan
- 0 +
just open up Internet Explorer. At the top, click tools -> internet
options. On the new window that pops up, click the Connections tab and
there in the middle of that window you should see some radio buttons to
click. Click the one that says "Never dial a connection".
Alternatively, you can just select the dial-up connections in the box
and click the remove button until they're all gone. Click ok out of
everything and you're all set.
-Shin
> good.
> aggravating.
> Thanks,
> John
Reply to Shin
> WGR614, the laptop connected with the Netgear WG511 PC Card. These
> seemed to work good. I then set up File & Printer Sharing between the
> two computers. That works good.
> choose to "Never dial a connection" but it will not stick. It keeps
> changing back to "Dial whenever a network connection is not present".
> This is getting aggravating.
> Thanks,
> John
Have a firewall/anti* thing? Some don't let things change network setting..
Changes are kept in memory/temp not on disk/perm.. A reboot and the memory
is gone (sort of like a stroke)
Reply to Anonymous
"Jonathan" <jonathanNO@SPAMsprintmail.com> wrote in message
news:qOKdncx81onF2UHcRVn-uQ@speakeasy.net...
> the
> good.
>> works
>> good.
> choose
>> back
>> aggravating.
>> Thanks,
>> John
> good luck,
> Jonathan
On both computers I am running WinXP (service pack 2).
I have been using a LAN for my connection for months before this started
happening. Seems it just started after I had already been using my Wireless
network for a few days and immediately after Networking the 2 computers.
Thanks,
John
Reply to Anonymous
"Shin" <shinma6980@netscape.net> wrote in message
news:12YCd.11095$wi2.3603@newssvr11.news.prodigy.com...
> click. Click the one that says "Never dial a connection". Alternatively,
> you can just select the dial-up connections in the box and click the
> remove button until they're all gone. Click ok out of everything and
> you're all set.
> -Shin
I guess you didn't read all my message.
quoted from my original message:
"But, since I set up Sharing between the computers, the Windows Dial-up
to
I can remove my one dial-up connection but it is for using my Cellphone to
be able to connect if and when Comcast Cable is not working and I would like
to be able to keep it as before and not have to re-set it up when the need
arises.
Thanks,
John
>> the laptop connected with the Netgear WG511 PC Card. These seemed to work
>> good.
>> works good.
>> Thanks,
>> John
Reply to Anonymous
"Peter Pan" <Marcs1102NOSPAM@HotmailNOSPAM.com> wrote in message
news:343307F452ef9U1@individual.net...
>> Thanks,
>> John
> setting.. Changes are kept in memory/temp not on disk/perm.. A reboot and
> the memory is gone (sort of like a stroke)
Yes, I use Windows Firewall. Would it keep popping up the dial-up
connection?
Reply to Anonymous
>> and there in the middle of that window you should see some radio
>> buttons to click. Click the one that says "Never dial a
>> connection". Alternatively, you can just select the dial-up
>> connections in the box and click the remove button until they're all
>> gone. Click ok out of everything and you're all set.
>> -Shin
> Dial-up connect box pops up. Each time I go into the connection
> settings and choose to "Never dial a connection" but it will not
> stick. It keeps changing back to
> Cellphone to be able to connect if and when Comcast Cable is not
> working and I would like to be able to keep it as before and not have
> to re-set it up when the need arises.
> Thanks,
> John
I have the same prob. I use a cell phone when traveling, and have a wifi at
home. Seems to be an undocumented "feature" (grrrr) of SP2. Started doing
that AFTER I did the upgrade. No solution yet, but just thought I'd chime in
with someone else having the same problem.
Reply to Anonymous
>>> is a desktop, the other a laptop. The desktop is wired to the
>>> Netgear WGR614, the laptop connected with the Netgear WG511 PC
>>> Card. These seemed to work good. I then set up File & Printer
>>> Sharing between the two computers. That works good.
>>> stick. It keeps changing back to "Dial whenever a network
>>> connection is not present". This is getting aggravating.
>>> Thanks,
>>> John
>> reboot and the memory is gone (sort of like a stroke)
> connection?
Really have no idea/solution (YET!, but I will perservere!)... I have tried
various combo of things (have Norton Systems/Norton Firewall/SP2 Firewall),
and even pulled em all.. As for the error, I have cable and a WiFi at home,
but usually get that when I travel and use the cell phone, normally with
Mobile Office, but I also tried it direct with Dial-up.
People usually treat me like a stupid idiot that can't read, and tell me
useless things to try that never work. Just wanted to let you know you
AREN'T crazy (i've been told that quite a few times).. Others have that
problem too.
Reply to Anonymous
news:343eh9F4580hpU1@individual.net...
>>> -Shin
>> Thanks,
>> John
> at home. Seems to be an undocumented "feature" (grrrr) of SP2. Started
> doing that AFTER I did the upgrade. No solution yet, but just thought I'd
> chime in with someone else having the same problem.
Thanks,
I never had this problem until after setting up Windows Networking w/ File
and Printer sharing. Been using SP2 since it was made available and also
using Cable connection for past 6 months. This just started this week.
John
Reply to Anonymous
I had the problem too recently with my desktop computers on a D-Link 524
router.
I just networked my computers and set every computer to share (2 desktops
and 1 laptop).
2 computers running WinXPSP2 with ZoneAlarm are both wired to the router.
After I included the range of IP addresses of the router in the "Trusted
Zone" on both computers and selected "Never Dial......." (also checking the
LAN settings to make sure no boxes are checked) I don't see that annoying
window anymore.
I am running AVG AntiVirus software.
I am not running the Windows Firewall.
Maybe I am lucky. <g>
later,
dave
(One out of many daves)
news:343f0mF41t262U1@individual.net...
>>>> Thanks,
>>>> John
>> connection?
> tried various combo of things (have Norton Systems/Norton Firewall/SP2
> Firewall), and even pulled em all.. As for the error, I have cable and a
> WiFi at home, but usually get that when I travel and use the cell phone,
> normally with Mobile Office, but I also tried it direct with Dial-up.
> problem too.
Reply to Anonymous
"dave AKA vwdoc1" <vwdoc1@ameritech.net> wrote in message
news:Mw2Dd.4942$Vj3.3376@newssvr17.news.prodigy.com...
>router.
> and 1 laptop).
> the LAN settings to make sure no boxes are checked) I don't see that
> annoying window anymore.
> later,
> dave
Dave,
I don't think you are particularly lucky, just that maybe I am unlucky. :-(
I have unchecked the "Never Dial" box hundreds of times. It just keeps
changing back before I need another web page when I am surfing.
I have turned off Windows Firewall, but installed Zone Alarm. Actually, I
tried it without any firewall. I have been using AVG Antivirus for over a
year.
Wish I could get lucky!
John
Reply to Anonymous
- 0 +
On Thu, 6 Jan 2005 12:10:48 -0500, "L'l John" <je_norrisstopspam@hotmail.com>
wrote:
<snip>
>Dave,
>year.
>John
Have you scanned your system for spyware/adware?
Reply to beretta
> you're all set.
> -Shin
Shin,
I just wanted to let you know that I finally followed your advice.
Finally I removed my cell phone modem from the list of dial-up connections,
which was the only dial-up connection I had, and that stopped the problem. I
had that installed for the past 6 months without any problems until I
Networked my two computers. The desktop is the only one affected.
I will probably wait until my cable connections fowls up before reinstalling
my Cell phone connection.
Thanks,
John
>> good.
>> works good.
>> Thanks,
>> John
Reply to Anonymous
"Beretta" <invalid@invalid.org> wrote in message
news:c9brt09aumet9kie31tsdqta4n7mimfp4a@4ax.com...
> wrote:
> <snip>
>>Dave,
>>year.
>>John
I have scanned with Ad-Aware and Spysubtract with nothing but tracking
cookies showing up.
Reply to Anonymous
There are 1090 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
