hehe, the + makes all the difference. Be SURE you get the 8kha+.
With a 1900 XP, windows XP, G3 TI 500, corsair Cas 2 ram, i ran 8.5k on 3dmark 2001 in the default bench. No overclocking, stock out of the box. The radeon only runs 8.4 k with the same setup.
Great, Thanks for the info. Would you recommend another motherboard over this one?? I have read that the 8KHA+ is one of the best boards for DDR and a AMD T-Bird.
