You have downloaded a program that contains spyware or adware. The spyware or adware has been removed but the program requires the spyware to be installed in order to run, without it you will get the Run Time error. This program runs on startup so you will have to uninstall the program that had the spyware associated with it.
Run Msconfig from the Start > Run window and turn off the progam that you downloaded, or uninstall the program.
If you still cannot find the program do a search for files that contain the word "Backweb"
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Well, he had just removed a virus from his computer, if that makes any difference. Will getting spyware or adware, then doing what you said still work?
