G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I need java in order to surf some sites on hte net... So i went to the sun
microsystems site and sownloaded the java program, but when i try to put it
on, i get a message half way through installation saying "error 1311: Source
file not found, check that this fale exists and that you have access to it."
then a path leading to my folder, and Content.IE5. I checked, it exists, but
when i click on it, manually, it wont open. so im guessing i dont have access
to it. but im an administrator for this comp. its a home computer and theres
only one. The OS i am using: Windows XP pro
