So heres the deal, I used to run a 2.8 ghz athlon in a basic HP bundle with integrated gfx. i later replaced the integrated gfx card with a 4800 radeon. could run most settings high and retain a 60+ fps cap and never bow under any load from the game.
But like all gamers i craved more power. So i bought a brand new Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
And a new GFX Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150534
and since it was such a change i had to reinstall my windows OS, Win 7 Home Premium 64 bit. I got everything re installed , my drivers and wow, it now asks me to Allow this program to make changes when opening wow, which it never did before. My mouse doesnt work right, only half the buttons work now. and the random lag from the mouse glitching is new, also i ran on ultra for a while it seemed to be alright then all of a sudden fps went to crap. i dropped all the hard settings to lowest it seemed to help but the game still isnt even in comparison to what i had before with worse hardware? What i notice most is randomly i will bog to 4fps. and it will not pick itself back up till the boss is downed or i die. It makes no sense to me. Im bummed because this seems to have been a waste of money. If anyone has an answer it would be amazing.
Thanks Chris
3.4Ghz AMD Phenom II [ GiGaBite Board] XFX Radeon HD 6790 [600w Power Supply]
And a new GFX Card
Thanks Chris
