Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > System Restore System Check Point
Forum Windows XP : Windows XP General Discussion - System Restore System Check Point
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
My computer has cesed to automaticly create system check points. I have
viewed the Scheduled Tasks and the task is missing. What arguments should I
attach to the path when creating a scheduled task to cause it to create a
restore point without prompting the user. (I'm assuming ammending the path is
the way to create a restore point without user input, if there is another way
please tell me)
Sponsored Links
Hi
Is the Task Scheduler Service running? From Start>Run type
services.msc
then scroll down the list. If the Task Scheduler Service isn't running,
right click on it and select Start.
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
"davep1553" <davep1553@discussions.microsoft.com> wrote in message
news:22EC9653-D74B-47BF-ADDD-D05E75BE4F5D@microsoft.com...
> I
> is
> way
> please tell me)
Reply to Anonymous
Please read the entire post before you post. I clearly stated that the
task for creating the system checkpoint is NOT present, so even if
the task shcedualer wasn't running that wouldn't be the only problem.
But yes the task schedualler is running and I'm 100% sure it's working
corectly because my antiviris still makes it's 3 times a week scan and
that is triggered by a task.
"Will Denny" wrote:
> Hi
> services.msc
> Will Denny
> > I
> > is
> > way
> > please tell me)
Reply to Anonymous
Hi
Eliminating certain options that aren't enabled/running may have helped your
problem!!
Will Denny
news:31FF21EF-B072-44EF-B8D4-FC777C969999@microsoft.com...
> "Will Denny" wrote:
>> Hi
>> services.msc
>> Will Denny
>> > should
>> > I
>> > a
>> > path
>> > is
>> > another
>> > way
>> > please tell me)
Reply to Anonymous
See if this helps:
http://windowsxp.mvps.org/checkpoints.htm
HTH
Meena
I
is
way
> please tell me)
Reply to Anonymous
That semes to have worked, I created a sheduled task that runs the scrip that
site provied and my computer should make a checkpoint every day at 5AM now.
"Meena" wrote:
> See if this helps:
> HTH
> Meena
> I
> is
> way
> > please tell me)
Reply to Anonymous
There are 637 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
