System Restore Filter Problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Assistance would be appreciated. Went to do a System Restore tonight, and
all previous Restore Points appear to have been deleted. Appears to be now
working OK, and I have created one as a test, which appears to work. After
finding problem, I checked the Event Viewer and found the following error
there.
<The System Restore filter encountered the unexpected error '0xC00000A1'
while processing the file 'shell32.dll' on the volume 'HarddiskVolume1'. It
has stopped monitoring the volume.>
Can anyone please explain what this means ? and is there anything I can do
to ensure it doesn't occur again ?
Kind Regards,
PhilC
G
Guest
Guest
Hi Phil,
What is the Event ID and Source from the Event Viewer?
Regards,
Bert Kinney [MS-MVP DTS]
http://dts-l.org/
> Restore tonight, and all previous Restore Points appear
> to have been deleted. Appears to be now working OK, and I
> following error there.
> error '0xC00000A1' while processing the file
> 'shell32.dll' on the volume 'HarddiskVolume1'. It has
> anything I can do to ensure it doesn't occur again ?
> Kind Regards,
> PhilC
