Hello this is my first thread and I apologize if I didnt put it in the right section.
I have a desktop custom build computer I got it for 6 months without any problem. I signed up and got a beta key for star wars the old republic I run the game for couple of hours without any problem but then I got an unexpected shut down and after that some more so I decided to check it out from the inside I opened it and relised that the power supply fan wasnt working and my power supply was overheating so I bought a new one and replaced it . The new one has same wats and it was correctly installed etc. After I tried to run the game again I got another shut down and my pc wouldnt start again. I tried to start it directly from mother board etc. The leds from motherboard are working like normal but it doesnt start. Anyone has an idea of what is the problem or how to solve it and will i be able to play the game after all ( i meet the system requirments)
my pc spec is
NVIDIA gts250
Prossecor : intel core i5
motherboard : intel desktop board DQ56TM executive series
ram: 2 bars 2 G each
If you need any more info just ask
Thank you in advance
my pc spec is
NVIDIA gts250
