In the middle of first build! help
I'm in the middle of first build and have a question on the power supply harness. I've connected the 20-pin power connector to motherboard and power supplies to drives and connections to front panel LED's. There are two other connectors that are coming out of the harness that I'm unsure of. One is a small brown connector with 2 pins with 1 black and 1 white twisted cables. The other plug has a lock tab and the wires are: 3 black 2 orange 1 red. The power supply is an Antec PP303X. Thanks for any help
2 answers Last reply
More about middle build help
  1. I know there's a new wire on the P/S that's for the P4, thats small and square, about 1/2 by 1/2, then there's a 1'' by 1/4 no ideal what that one is. Hope this helps. Bump
    defrage is child's play-fdisk
  2. the small P4 one that you are talking about has 4 wires,
    in this sort of configuration...
    the white one is like for server motherboards, and i dont know about the other one...
    -DAvid
    -Live, Learn, then build your own computer!-
Motherboards Power Supplies Build
